Gotta share ;)
http://img177.imageshack.us/img177/6...20x8br0.th.jpg
520x8 1m SuperPI
Gotta share ;)
520x8 1m SuperPI
Did you use SetFSB because you couldn't get this high by changing it in the bios?Quote:
Originally Posted by DStealth
I can set 510-515 in bios and boot into windows, then setfsb it :)Quote:
Originally Posted by JPH1589
Also like the fact that i'm running all air cooled config and ram 1040mhz 3-4-3-4 2.2v:eek:
I noticed a couple of things.Quote:
1. When I run setfsb on this board, it automatically assumes the memory is on a 1:1 divider and displays that speed no matter what speed the memory is running.
2. Also noticed that my Clock generator chip is a different number than yours.
Could you please do screen shots of all your validated cpuz tabs on the screen together. I am curious about a few things, including whether you have a C2 or C1 board. Mine is a C2 from August.
Edit.....never mind......just anomalies........he has a new beta version that doesn't work right either. It just read my FSB at 200 when it is running 288
Thanks!
You using water cooling? 27c idle is pretty good. What cooler you got if not water cooling..Quote:
Tt BT + Tt case fan 120 2800rpm Opened window next to PC. You don't think i'm useing 520x8 24/7 and can cool down this cihip :cool:Quote:
Originally Posted by markopoleo
Here is my best air so far same conditions - open windows ambient around the PC about + 5 to + 7 celsius:cool:
http://img171.imageshack.us/my.php?image=1m4266et9.jpg
I'm running 3920 /490x8/ 24/7 @ 1.43v Load 1.475v set in bios and temp with Orthos are under 70's* :)
Figured as much. Can't open windows here :P 60-62c highest i would want to go under load. What do you run it at not under load under normal conditions? My intel stock HSF runs pretty hot not under load around 50c (1.86 @2.8ghz default voltage), under load though it is only 60-61c..i run under load 24/7 though for BOINC :D
Hmm, interesting, I want to know your settings in BIOS! I mean memory setings and subtimeings, it would be nice to know them all if posible :) Maybe I can get 500+ Orthos stable with my board, my problem was that with 4-4-4-12 it was not stable, but with 4-4-3-9 was, so maybe with 3-4-3-4 I can run even more stable? :stick: :DQuote:
:slobber:Quote:
Thats so freaking awsome
Kunaak needed 3.4v for 1060Mhz 3-3-3-10 :o
http://www.xtremesystems.org/forums/...2&postcount=20
Yes, but 3-3-3- is very different story from 3-4-3-4 when comes to 965 and 975 chipsets .My opinion is that 3-4-3-4 is no different than 4-4-3-4 and a little faster than 4-4-4-4 when set hrough memset :confused:Quote:
Originally Posted by DeToNaToR.cl
I'm on a stock HSF as well with my E6300 at 2.8ghz and default vcore, but I'm idling at 23c and goes up to 50c load. Your ambience must be high?Quote:
ok wait guys and tell me that in 965P-DS3P Rev2.0 Micron D9 problem solved?
Went from Asus P5B-E to the DS3, updated to F8i today and started playing.
http://img479.imageshack.us/img479/6...00gbds3nf2.jpg
Originally Posted by HeadOn
Around 73F inside during winter. Still, 23c vs 50c idle is pretty big difference.:confused:
No. I have non troubles with cold boots. I had only cold boot problems with bios F1 and F2.Quote:
Originally Posted by aldamon
But bios F8I don't let me boot higher than 460fsb. :stick:
Nearly 2 months now with out a new BIOS. Surprising.
on a side note the DS3P (rev2) looks to be awesome. It has everything that was missing from the DS3. Add in all of those things and the rev 2 looks like it could be the perfect board. And will probably knock the P5B-E off from being the top OC'ing 965 mobo.
so theres no f8 bios coming out for the D9 fix??
what a difference a psu makes...wouldn't go more than 2 hours with my old psu...
http://img385.imageshack.us/img385/4...c070900ep3.gif
You do know your temperatures are 76ºC?Quote:
Originally Posted by Tac0
Those temperatures kill.
Yah 73c is nuts to run at.
My friend's 6600 runs at 3.4 ghz and hits 68-73c with a zalman heatpipe cooler. This is a SI 128; I just kicked orthos off b4 going to bed and it just kept running. Takes it a while to get that hot; I don't normally "marathon stress". What are you guys on air running?
60c is tops i would go if you run it underload a lot. C2D throttle at 85c so 70+ is pretty extreme.
What cooler is most popular? i just changed out the fan on my SI 128; the cooler itself it was seated properly and I'm running orthos now (also dropped my vcore to 1.375 from 1.4). going to comtinue to drop it till it hits the wall (early failure in Orthos).Quote:
I'm 50ºC loaded, 3.5ghz with 1.4V on my E6300. (TT120)
thats a loud fan @ 97 cfm...mines rated like 70 (the one I switched to), but I have an 80 intake and an 80 exhaust right next to the cooler. What heatsink?Quote:
Originally Posted by Noob-ftw
http://img221.imageshack.us/img221/1...c072145nc1.gif
