What BIOS version are you running? Are you on water or Air?
That's a high QPI! :shocked:
Maybe that's why I have such trouble...
Perhaps you can help me out.
I've had a hell of a time trying to run my uncore @ 4000Mhz. I can run 2000Mhz no problem with my QPI @ 1.362v and CPU is the same @ 4.2Ghz
What kind of temps do you get on your Northbridge? Your CPU? How long have you been running your QPI at that voltage? is it safe?
I'll do this myself if it's safe and doesn't damage anything. :shrug:
According this http://www.gskill.us/forum/showthrea...t=F3-16000CL9T i run this setup for about 4 months.
My cpu is in range 40c to 85c(linx) and now for northbridge/southbridge try to reinstall thermal paste and correct my first vga position because i believe that touch to m/b block and increase the temps.
I was unable to run XMP for Corsair Dominator GT CMT6GX3M3A2000C8. It just dont boot. Any help?
Edit: Bios version 1005
http://www.xtremeshack.com/immagine/t67928_4400.jpg
test with these settings......
Nice Xeon you have there, killer IMC.
Apparently you have made up your mind about a company you know nothing about. I imagine you probably just got into water cooling and went to some website that said "Koolance sucks, BP for the win". Seriously, if you have never used their products, how can you comment on them? I have used more than 10 CPU blocks, probably 8 or more MB blocks, a crap load of GPU blocks, all of these from various companies and you know what I figured out? They're all pretty much the same. Different colors, minor tweaks, cool tricks, but all made from copper, some nickel plated, some not and all perform withing a few degrees of each other. Seriously, it really comes down to what looks good for your build and what makes your life easier running your tubing and how much you want to spend. XSPC makes a great GPU block that is about $30-$40 cheaper than the rest and it performs just as good, but it doesn't look as sweet as an EK block or a Koolance block or even the BP blocks. I use them all and don't limit it myself to any one brand, no reason too.
i was just looking at the EK HF (high flow) cpu block, a bit expensive but i think it will be my next cpu block..
Yeah, I have the older EK Supreme Classified and I love how it looks, but flow on it is terrible. When I do change my blocks out this next time I will probably do the EK HF block to match the rest of my system. I don't expect any performance difference, but I like trying new stuff.
There's also pretty strong evidence that the Marvell controller doesn't pass through TRIM.
http://forum.crucial.com/t5/Solid-St...AID/td-p/18454
Here's the whole thread leading up to the above one.
http://www.forum.crucial.com/t5/Soli...-no/td-p/11109
wheres the 5ghz + oc's ?
to much talking guys :p:
seriously nice temps stock heatsink vs koolance block >_<
http://img819.imageshack.us/img819/6375/oudk.jpg
http://img708.imageshack.us/img708/9955/tmpss.jpg
You spelled "percent" wrong...
sorry I can't help myself...
Then you googled my name and realized I've been doing this since before xtremesystems existed. Way to do your research.
Your numbers mean nothing to me, and neither do your arguments. Just another koolance fanboy.
I use what works, what's convenient, and what's good. I have no other criteria. If koolance came out with a compelling product, I'd promote it just like any other good piece of hardware.
Oh yeah, and then you googled 'hydraulic quick disconenct' and realized that everyone makes them.
Is it necessary to plug in the 2 molex connectors on the board if running two videocards (overclocked on air), or is that only necessary for running 3-4 heavily overclocked cards?
