Originally Posted by Burnt_Ram
if you have cpuz, check in the memory tab and it should tell you what speed your memory is running at. if anyone running the dfi lanparty sli-dr, please share your memory settings in bios. Thank you.
it's running at 201 mhz, so thats probably the equivelent of a 133 divider.Quote:
cool, thanks for sharing. on my ongoing ocing adventure, by relaxing my memory timings, i'm able to push this opty 170 to 2.9Ghz. however, it's not orthos stable, but superpi v1.5 seems to run fine. my mem divider is 180 so the memory is theoretically running at 264Mhz. i guess my rig is not considered stable, but i can live with it as 3dmark 2k6 finishes all tests fine. i wonder why orthos is crapping out though.
which core is crapping out on you?
Getting over that 3ghz hump on air is extremely rare ;) usually you need more volts than aircooling can handle.Quote:
it's always cpu0 that craps out on me :(. also cpu0 always shows lower temp under full load and the difference is 2-3 degrees. i'm tempted to pop out the ihs, but too scare to do it :). eventhough prime95 or orthos fails on me and the system is not 100% stable, i'm still using it to run folding, rosetta(only 1 run), vmware(ubuntu and fedora c6) all at the same time. i can also play a game completely, but that's gpu dependant so that's not indicative of stability. i'd relaxed the memory settings in the bios as much as i can. weather is too warm here these days so that might be a factor too. is vcore at 1.55 for 24/7 normal to use? i wish i can have a chip that can do 2.9 easily and at low vcore :). oh well.
AMD Opteron 175, boxed (JackHammer Dual-core) CCBWE 0550 UPMW
i will buy this Opteron, maybe its a good stepping and i can hit 2,9-3,0 gHz.....
what you mean...???
Hey y'all,
Been reading up quite a bit on these (and a few other) forums, and I must say that I've been bitten by the DC Opteron bug as well!
I'm currently stress-testing a 170 on my dad's rig (on an honestly poopy A8V-E SE), and his is a CCBWE 0534SPMW. It's running dual-Prime95 @ 2.20GHz, 1.35V at the moment, and I may just freeze the spec there because the board has already corrupted the WinXP install with a previous OC attempt (yesterday).
My rig is running the 165 referenced in the subject line (CCBBE 0616XPMW), which I got from TigerDirect, at a dual-P95 12+ hr. stable 2.70GHz @ 1.37V. The motherboard is my beloved ASUS A8N32-SLI Deluxe. The Opty is also running the stock cooler. I may push this jewel a tiny bit harder once I get my TJ09B (Silverstone Temjin) from work, where I had it delivered this week. (Too bad I got sick and couldn't get it by this weekend!) :D
Great procs, these dual-core Skt939 Opterons!
CCBWE steppings are usually bad for 2.9 - 3 G's. You will be lucky if a t least you hit 2.6 or 2.7 with very high voltages.... Refer to the first page for the database. Although its for 165's I think the stepping is the same for overclocking. Stay away from those. IMHO you'd be better by getting a CCBBE 165 (if your mobo can take high HTT speeds).Quote:
Originally Posted by Dragon69
Just my 2 c
running orthos on my 0610dpmw(de-lidded now) at 2.99ghz 1.475 volts.
10 minutes golden so far. i maybe be able to hit 3ghz with this chip at 1.5 volts.
i hope anyway...
Originally Posted by txtmstrjoe
Check my post about CCBWE, post #3094.
And yeah!! I see you're happy with your XPMW, I am too!! check my sig! Enjoy your Opty!! :toast:
some of those hit 3ghz on air, easier with water. it's a good stepping but there ARE bad ones. Good thing is, it's one of the best of the CCBWE series, and it can take some cold (other than CCB1E's and CCBBE's, they have huge coldbugs)Quote:
I have found limit @ original voltage I think ...
307x9 @ all original voltages
ht 3x / ram divider @ 100
http://img147.imageshack.us/img147/6...m100ak1.th.jpg
I'm on 24h stable 306x9 now and still searching a lame to remove ihs ^^
you would have found out alot quicker than 16 hours if you set your priority to 10.
just picked up a 165, this thing is incredible. Threw it in 10 minutes ago and its sitting at 3ghz, 333x9, 1ghz HT on 1.536v. I need to hook it up to the prommy...
Ill post pics once I've ran this little nukka to the limit.
Originally Posted by Semper Fi
where did you get your 165? congrats. have fun ocing.
Watch out for the cold bug!Quote:
ordered it from newegg about a week ago. Sitting at 3.1 now, completely stable. Had it burning in overnight. I'm very impressed so far, the performance at 3ghz compared to my old 3700+ at the same speed is incredible. If I can get it to 3.2 without the prommy Ill be very happy. I need some new ram though, this OCZ stuff I bought wont break 210mhz regardless of voltage or timings.Quote:
awesome, congrats on the nice find. seems like newegg got some good opty 165s. with my luck, i'll probably get an average ocer if i order one from them. could you please tell me your memory settings in bios and what dividider you're running to achieve 3100. thanks.
Max with all voltages @ auto (cpu=1,3v)
306x9 (ram divider @ 100 )
StressPrime Orthos 32h passed
http://img294.imageshack.us/img294/8...toraao4.th.jpghttp://img294.imageshack.us/img294/9...06x9jg7.th.jpg
Hmmm what stepping did you get?
i wish the people who are reaching 2900-3000Mhz would show some more details like vcore, memory divider, memory settings in bios(if possible), vdimm, etc.. thanks.
I think DS/DDS is 8,1 becuse of Venus + 4x512mb(1,1 if i use 2x512mb)
If you want more settings then ask me :) , Vdimm is abit high for this low ram speed but i have it high for some testings..All settings are not tweaked yet.. waiting for some new 2x512mb bh5 sticks before i fix all things..(hope full i can run 166 divider instead of 150 divider on them then) 270mhz+ instead of 250mhz.
http://img218.imageshack.us/img218/3063/settingsun9.jpg
Pics, pics, pics!!! :D
i've decided on this speed for 24/7 use. it's at 1.475 volts. and has been prime stable for a 18+ hour period..
sorry for the size of the pic...
http://haste.4saken.org/pics/uncapped170/0610dpmw.jpg
