HI,
I believe the "50I" chips are .11 Power chip. CADT :(
HI,
Oh well so I wont be doing much ocing with them then. :(Quote:
Originally Posted by mike047
found out...they don't have the dots :(Quote:
Originally Posted by Crazykooter
So what does the dimple in the lower right hand corner mean? power chips?
just a really bad update on my regulat TM 50D UTT
currently at 260mhz 1.5-2-2-5-7-16 with 3.5v :D 2x512mb sticks
this stuff rocks
Hi,Quote:
The set I have will run 230 with an XP 2400 mobile. [2.5-3-3-11] . It is on a vdimm modded Albatron KX18D, Voltage over 3.0 doesn't make any difference. I run it at 2.97v.
So I take it this stuff doesnt ship with winbond chips anymore?
Hi,Quote:
Originally Posted by AMD-me
The last 4 sticks of Twinmos SP PC3200 [256] that I bought from New Egg was 1A4T[utt/BH-5?] 44B chips with all the dots, etc.
New Egg doesn't have any SP listed right now:(
Well the new non speed premium twinmos is garbage ram. It doesnt oc for nothing. Oh well. I was expecting it. Just to let yall know so you dont buy this stuff if ya want to oc. :fact:
how did those 44B chips perform. the 2x512 bh-5 sticks i have are the same chips. i'm waiting on an rma for my cpu(bad mem controller) and was wondering if they're fairly decent or not. better, as good, or not as good as the 50D chips?Quote:
I haven't had any 50D's, but the 44b's I don't like as well as the 44D's.Quote:
Originally Posted by omga14
I am still on XP platforms, so I don't know how it would do on a 64.
I actually was happy to get the 44b but after trying it out a little, I was disappointed. Maybe with more testing I'll grow more fond of them:D
so what have you been able to get out of em' so far?
HI,
220, if I remember correctly, the 44D's go about 230 but with more voltage[3.375v] @ 2-2-2-11. I didn't test the 44b's real hard yet.
These numbers are capable of 24/7 folding, prime95/OCCT stable.
I have 1 stick which does 2.5-3-3-8 @2.8v 1T apsolutely fine. I have had this stick for ages and works a treat.
My other stick (fresh from RMA, still AA4T) fails memtest 2.5-3-3-8 @2.8v 1T. It is apsolutely fine at 2T but fails 1T.
Does this mean a bad stick (and I can RMA?) or is this just... really unlucky? I mean will a burn in help or am I just stuck ...?
It means the new stick needs MORE than 2.8V to operate. Give it 3.0 and see what happens.
So is TMSP no longer produced and distributed in the US? Can't find them anywhere...
Yep. The party is over. No more cheap CH-UTT AA4T. Whatever loose ICs available were likely snatched up my the boutique memory companies. BH 1A4T may only be in the Europeon market under the "Twister" branding.
hello Xtreme Member,
me recently just bought dfi ultra-d , there are so many memory timing setting in the genie bios
so confuse, anybody here can just help me to set the timing on my UTT running 250fsb@3.4v (using booster) from the first line to till the last
thx
Hello raydelee, the term "Xtreme Member" is given to Registered Users who have 100 posts and more... when they get 1000 posts they are called "Xtreme Addict" if i recall correctly ;)
sorry! i'm just newbie here :toast:Quote:
Originally Posted by Garrett
Added another 2x512MB of Twinmos SP3500 BH-5. After some burn-in these are windows-memtest, SPI32M, 3DMark, etc stable clocks. Here's SPI1M for comparison:
easiest way to hit 250, set your ram timings to 1T, run a 1:1 ratio, set your main 4 timings to 2 2 2 6-10, set everything else to auto. crank the volts :) Once you find a stable spot, then u can tweak the rest of the timings.
Don't order any of the TMSP from Newegg's refurbs no matter how tempting it is. I ordered two 512mb sticks; one wasn't SP and the other errored in memtest at the rated speed and timings at any vdimm.
Time to RMA these sticks and order some Value VX...
:welcome:
I am greet unhappy :shrug: ( I as yet) owner 4x512MB Twinmos I have BH5 UTT 1A4Tgdyż problems with achievement stable settings (even SPD) :{
All on 2x512B is OK
I wait on help :) you can pass (how mat 4x512MB) your settings from biosu
My config this:
DFI NF4 Ultra - D bios 412-2, A64 3000 + venice, chieftec 420W,
I apologize for my English
how much voltage are you giving the ram? you might need 2.9v's or more just for stability.
