Originally Posted by Losphoron
Bios 1.B oficial,NV/ati oc disabled, C'n'Q disabled, fw enabled (i read that are problems with 9600 chipsets with it disabled),the rest disabled...
DDR setted at 166 instead 200..When it boot up it shows DDR 333 Dual Channel and another thing the slots for dual channel are 3 and 4..I tried 1 and 2 in the past and it seems there is no difference bettween them..Anyway in the MSI Memory compatibility list they give them the ok in the 3 and 4 slots..I don't know why but now i have them in 3 and 4..
Vcore: +10%
fsb: 260
Htt: 3x (with 4x is not working at 260mhz)
Memory voltage: default
vga: 1.60v (with 1.5v the games freeze with 260mhz setted fsb)
Multiplier: 9x
timings: 2.5,3,3,7 2T (with 1t i am not sure is stable and the performance increase is very very low)..
Temperature is not a problem because my cooler is pretty good (Arctic Cooling 64 ultra TCL)..In idle 34 degree celsius and in full load 42 degrees..This is without the second big on the back of the case that bring out the air from inside..That is pretty noisy but very eficient..With that i get in idle about 27 degrees and in full load about 36 degree..
Thanks..
