CPU VID Control - DK boards don't have that option.
thanks praz, I take it I gotta use special add for any volt change? Thats lame.
Most boards have one or the other as an option to alter VCORE. The UT/LT series is pretty much unique having both.
edit: nvm;)
I got my board running with my E8400, question! I am sitting right now at 3780 mhz voltage on auto which is 1.24 and well pretty much everything else on Auto :P!!!! hre goes the question, If I leave everything on auto will it give me good results or what can I expect, mem is running at 420 mhz 1:1, is just that im new with this board's bios and there is just so much I can tweek
do u have single or double sided tracers, and use the 333 ram straps whenever u can
also start with 1.5-1.6V NB and then adjust the ram to aggressive and your phases, then gtl last
and the board might overvolt if u leave voltages on auto, or leave vdroop control enabled over 1.45V
they are double sided, also look at this wth???
http://i184.photobucket.com/albums/x...to88/Temps.jpg
im confident my temp is 30C and noty 40 nor 50 :S!!!!
if those are double sided try 333/800 so ur at 1009mhz with 4-4-4-10 with aggressive on your sub timings and e-a-e-e-e/e-a-a-e-e for your phases, and u will need like 2.15V ram and 1.5-1.55V NB
I'd put a lot more confidence in the Core temp and Real temp programs. Smart Guardian always read low for me, plus there's only one reading.
If you doubt one of the numbers, reach in the case and touch the heatsink closest to the core. If it's room temp or lower it's probably closer to 30, but if it's warmer than room temp I'd say 50.
this is max for my cpu on air 1.58v cpu 2.24vdmm
i dont do suicide on my 24/7 rig:p:
there is a problem with 3870x2's and the x38s?
Ill try those settings in a bit, rright now I have my NB voltage at 1.28 my ram is running at 1.88v 430 1:1
My room temp is 20 C, I measured the liquid on the reservoir and its 22-24C I dont know if its because the WC setup?, RES-PUMP-CPU-NB-RAD-RES what ddo u think?
tnx:up: I just felt in love when I saw this wallpaper, funny I don't use Dark wallpapers, always ligh colors because my eyes feel comfortable, but this had to be here :p: btw it is a wallpaper from a band called Dream Theater(which is my fav band:up:)
incompatable in a "doesnt work correctly" or a "doesnt work at all" sence?
yeah im trying to hold out...
If it works for you thats great but the fact is for the majority of users the combination is nothing but trouble. Normal 3870x2 cards suffer from constant freezing and most 4 port versions won't even allow the board to boot.
GeCube is the only card manufacturer looking for a solution to these issues. Neither them nor DFI have found a work-around as of yet.
so the 3d crashes are board related with them
