Nope, I agree with AstroCreep...boards are def different.
New-b on post #3075 shows the whole area here is different.
The caps being a different size would not warrant a Revision Change.
It is normal for board manufacturers to change the Version Number by a decimal place when there are changes made to the board layout. If they change a surface mounted component, they usually leave the Version number alone & attatch a sticker with a Letter to denote the change. In this case, version 1.1 only has 3 Resistors which means a change in PCB, hence the change in Revision number.
Anyone know why they made this change??
