A good price would be below $300Quote:
Almost every good memory will cost less than 300.Quote:
Originally Posted by askimo
SUPER TALENT
Model T800UX2GC4
G.SKILL
Model F2-6400PHU2-2GBHZ
G.SKILL
Model F2-6400CL4D-2GBHK Looks like G.Skill changed the chip to a Micron D9 on this. Cas 4435
Crucial Anniversary edition PC5400 , if you can find...
Etc...
finally all was good with my p5b but ... always seems to a but with these boards :D my keyboard doesnt work on ps2 port :mad: how the **** am i suposed to get into bios now ? usb doesnt seem to work before windows starts to load perhaps i forgot to set usb keyboard support but cant remember seeing that setting in bios. Offcourse ive tried 3 different keyboards.
Which one of the OCZ models use Micron memory? Here in Canada the variety of brands are limitedQuote:
Getttosmurf
take a good look at the PS2 connector , if it looks ok than you have no choice but to return the mobo.
3 kbd, all not good ? no chance , but the mobo.
What cooling do you use?Quote:
Originally Posted by Wang
Anyway to keep my onboard sound ang reduce boot tines? when I followed thiese instruction my boot times were 2=X as fast, but I get no sound at all. What did I miss here. When I do the first bolded item, the second is already done when I reboot.Quote:
Originally Posted by Angelico_Payne
I would prefer not to install a PCI sound card.
I have this combo.Quote:
RAM works out of the box. needs 2.0v to be stable.
Remember to manually set timings (4-4-4-15) as SPD sets them conservatively
Guy I have had a problem on my yukon ports since getting this and maybe someone can help.
When I transfer a file to the p5b I get a thruput of 1-2 MB and its bouncing everywhere. I have 3 other systems on my network and all of them get 11-12MB thruput send and receive. The p5b sends at 12MB to any of the systems fine.
BUT like I said I can't write to this system above 2MB and even then its bouncing everywhere.
tried different router and cables and nothing seems to change.
I went to the marvel site and dl the latest drivers I could find and installed them no change.
ps I am using 607 bios just running 365 on a 6600 to keep it cool...it will go over 400 but temps are terrible with ninja cooler...need water LOL
should I update? had a heck of a time getting it over 350 so hate to start that battle over again.
thanks big time for any help I am lost
Hi
Anyone have problems with clockgen ? i can run 459fsb all day but someone
told i would be beter starting at 400 in bios because of the strap thingy then uping it in widows with
Clockgen with the cy28551 pll so i have tired but if i move it more than 430 it locks the pc up i have to shut it down and restart by power switch :stick: any ideas ??
thanks nick
Originally Posted by Morph
that's the tradeoff for tighter timings. you will find it rough going much higher.
Thanks for your help. Are you, or somebody from this forum is familiar with this memory:Quote:
Originally Posted by strad
OCZ 2N900SR2GK 2GB Dual kit
What kinds of chips are used?
Has anyone given the new BIOS a try?
If you mean 0910 yes.
Testing it now:D
too early to tell at this moment
I just flashed 0910 last night .
I did notice the asus probe CPU temp updates more regular
If I see anything worth posting I'll reply :toast:
EIST works in Vista now ooh, another fun little thing to try out.
I was browsing through and I saw 1004 bios, I tried to download but it kept telling me that the server was too busy, I refresh and it was gone....?????? Anyone else see BIOS 1004, I promise that I'm not drunk and that I'm not smoking any time of recreational drugs.
:eek: your right
Anyone having problem with EZ Flash 2 + usb drive?!
http://www.xtremesystems.org/forums/...d.php?t=131413
My rom type is: SST 25LF080
This is a brand new board from Fry's.
I'm gonna test 1004 to see what's different.
Testing it now.....
It looks to be for the new processor 1333fsb and red letter warnings about the flash process.
down grading ? :shrug:
Can a Brotha get a copy of BIOS 1004....Thanks.
Try the Europe linkQuote:
Originally Posted by nicepun
Arigato..Thank you...Obrigado...Merci...Gracias...:woot:Quote:
Originally Posted by kwalker
The link above doesn't work. Is there actually a new bios release? Seems to soon after the 0910 bios.
If there is could someone upload it somwhere else?
Thanks!
EDIT: In fact it works, I had to disable my proxy. :D
