I think you should read the hardware specs in my sig. I'm running the same CPU. Trans boost enabled kills benchmark scores for me. I get faster SuperPi times with it off.
Well I'm back up and running with my new Thermalright Ultra 120 eXtreme(with 120mm Antec Tricool Blue fan) and HR-05 IFX NB and SB coolers.
First off is a side view:
http://img440.imageshack.us/img440/9449/case1xa2.th.png
I don't think I'll bother with any fans for the HR-05's because as you can see there are fans already on them effectively:
http://img440.imageshack.us/img440/9292/case2ng5.th.png
Bit of a tight fit but the CPU has dropped a good 5-6ºC, the NB has dropped 2-3ºC and the SB has dropped 3-4ºC! Perhaps I will add one fan to the NB though...
I have refitted the original Asus mosfet heatsink and bizarrely that's dropped 1-2ºC too. Maybe the NB was warming the mosfet with the old heatpipe link up!
you guys should just get an add raid controller. it's faster and you can take it with you to your next motherboard. There are cards that can fit in the 1x pci-e slots you don't use.
Ok, so before I installed my new Thermalright bits I ran 3dMark06 at my current stable 500fsb on Bios 0802. The only other thing thats changed is my memory, I had 800mhz and now have 1066mhz memory.
Here are a couple of before and after shots. These were taken as soon as 3dMark06 finished and showed the result, so as near to full load as I can get them
Before:
http://img135.imageshack.us/img135/3...0fsbsh1.th.png
After:
http://img135.imageshack.us/img135/5...bnewjw6.th.png
I'm not sure why the voltages are so different but the temps speak for themselves! Basically, its running stable with less Volts and its running cooler. Money well spent there I think!
Thanks buddy :)
I reckon you're right. I tried again and had great fun getting the system to POST with the 7 ratio at 477FSB. Each 1 FSB up from 470 needed something adjusted. Enabling Static Read Control got me up 1 FSB, adding some more voltage got me up another 1 FSB and then nothing helped getting it above 477FSB :rofl:
465FSB is good to go and 3.733GHz out of an old B2 E6600 is excellent enough to tide over till Penryn, when the real fun will start :D
Time to go do some more tweaking. Who knows though, as you say, maybe a newer BIOS in the future will do some magic :yepp:
Cheers buddy.
I ran into this issue when I tried to install Vista onto two "right out of the box" SATA drives that had not yet been initialized or partitioned. I had to "initialize" the drives before installing Vista.
Nurn,
I think you’re on to something.
How exactly did you initialize the drives?
I’m trying to load Vista 64 on only two of my four drives (RAID 0 on the two 74 GB Raptors) for an eventual Vista 64/XP dual boot setup.
I had this very same setup when I had the Evga 680i SLI motherboard installed and it ran fine and did not give me any problems loading Vista 64.
By the way, thanks for the link to the Microsoft info. I’m pretty certain that this is the problem; the symptoms that are mentioned in the link are exactly what I’m experiencing.
I also noticed that with the Maximus Formula setup I have all four drives showing up when I go to install the RAID drivers in Windows setup. With the Evga 680i board only the two drives that were configured in the Nvidia RAID utility are present during Windows Vista setup. I’m wondering if the two drives in RAID and the other two spare drives are causing the confusion with the X38 chipset. It almost sounds like the two spares will have to be disconnected during Windows Vista setup.
Asus Maximus Formula SE / BIOS 901
Core 2 X6800
Corsair XMS2 Dominator 4GB DDR2 800 (PC2 6400/C-4)
Evga 8800 Ultra “Superclocked”
Creative X-Fi Fatal1ty
2x WD 10,000 RPM Raptors (74GB) (RAID 0) -Windows Vista Ultimate/64 Bit
2x WD 10,000 RPM Raptors (150GB) (RAID 0) -Windows XP Pro/SP2
PC Power and Cooling 1000Watt SR
SilverStone TJ-09 (Black)
Son of a..
430x9 unstable
435x9 unstable
440x9 unstable
Could have been my backup power supply causing these problem? because right now the Antec is getting replaced for a 3rd time because it can't power my 8800GTX, so I'm using a older power supply, a 680W
WB, it really sounds like you're enabling something that shouldn't be... or some stupid wrong setting somewhere. i don't understand it.
I'm running beta OCCT, I can't get anything stable in it, no matter what.
right now I'm using
Code:Extreme Tweaker
Ai Overclock Tuner : Manual
OC From CPU Level Up : AUTO
CPU Ratio Control : Manual
- Ratio CMOS Setting : 9
FSB Frequency : 430
FSB Strap to North Bridge : AUTO
PCI-E Frequency: 100
DRAM Frequency: DDR2-1033
DRAM Command Rate : 2T
DRAM Timing Control: Auto
DRAM Static Read Control: AUTO
Ai Clock Twister : Strong
Transaction Booster : AUTO
CPU Voltage : 1.550
CPU PLL Voltage : 1.60
North Bridge Voltage : 1.65
DRAM Voltage : 2.22
FSB Termination Voltage : 1.50
South Bridge Voltage : AUTO
CPU GTL Reference : x67
North Bridge GTL Reference : x67
DDR2 Controller REF Voltage : AUTO
SB 1.5V Voltage : AUTO
NB LED Selection : NB Volt
SB LED Selection : SB Volt
CPU LED Selection : CPU VOlt
Voltiminder LED : Disabled
Advanced CPU Configuration
C1E Suppport : Disabled
CPU TM Function : Disabled
Vanderpool Technology : Disabled
Execute Disable Bit : Disabled
Max CPUID Value Limit : Disabled
can u guys provide me a link to the beta occt?
i cant seem to find the version with the slider
thanks
I have question about this function. When i change from peg/pci to pci/peg - my video card dont load, but the system is runing - why ?
For what is this function, and how i must set this ?
http://img150.imageshack.us/img150/2577/dsc06782ei8.jpg
ok now i'm understand :)
And this PEG PORT CONTROL - can i disabled or not ?
