Hi guys,
I'm new at Intel's club but not at DFI's (good old nf4..)
Set up new rig as in my sig n trying to squeeze a bit fm it.
Right now i'm stuck at relatively low fsb n hope you gonna help me:
Code:
-> Voltage Settings
CPU VID Control: 1.40000V
CPU VID Special Add: Auto
DRAM Voltage Control: 2.150V
SB 1.05V Voltage: 1.070V
SB Core/CPU PLL Voltage: 1.55V
NB Core Voltage: 1.50V
CPU VTT Voltage: 1.50V
Vcore Droop Control: Disabled
Clockgen Voltage Control: 3.45v
GTL+ Buffers Strength: Strong
Host Slew Rate: Weak
GTL REF Voltage Control: Enable
CPU GTL 1/3 REF Volt: 102
CPU GTL 0/2 REF Volt: 102
North Bridge GTL REF Volt: 102
Exist Setup Shutdown: Mode 2
CLOCK VC0 divider: AUTO
CPU Clock Ratio: x8
- Target CPU Clock: 3360 MHz
CPU Clock: 420 MHz
Boot Up Clock: Auto
DRAM Speed: 333/667
- Target DRAM Speed: DDR2 841
PCIE Clock: 100 MHz
PCIE Slot Config: 1x 1x
CPU load temp is 50C (CoreTemp)
DRAM Timings all on AUTO yet, resulting in 5-5-5-15
Any help to push it more? I would like to hit fsb 450MHz.
