I would like to see some more LCB9E results!
I've got one.1.4v to 2.7 same as you.Got and 2.9 with 1.5 but not tested yet.Got no time
I have the supposedly best stepping for opteron 165, CCBBE 0617 FPMW and I can't get it to be stable past 2.85 GHZ. I can benchmark and games upto 2.95 GHZ but p95 fails instantly if I go over 2.85 GHZ. On stock volts I am prime stable at 2.72 ghz but to get to 2.85 I need 1.55V...This is really annoying. Everyone else with this stepping is hitting atleast 3.0 and some even 3.1+ and I cant even get 2.85+. I have a proven mobo/ram combination since I can get my opty 144 stable to 2.97 GHZ. But still to be on the safe side I am running my RAM with really loose timings @ 215 MHZ. My HTT multiplier is set to 3x. Temperatures are'nt an issue since I am getting 22/45 idle/load at 1.55v with a lapped thermaltake tower 112 and AS5. I am work right now but when I go home I will try:
1) Lowering my RAM divider even further, down to 100 mhz..I am 99% sure this wont help but you never know. G-Skills tend to act funny with dividers.
2) Lowering my HT down to 2X (Its at 3X ATM). Someone mentioned you need to do this once you go past 345 MHZ HTT.
3) Make sure my PWMIC temps are OK with 1.55V. NTune does not show this and speedfan reedings are all over the place. I need to get smartguardian for my DFI infinity.
We'll see what happens. My cooling is the best you can have with air but its a shame I cant utilize it in order to get to 3.0 GHZ :mad:
I doubt you can do 3ghz on air under 1.55v with the 0617 but I'm pretty sure you be able to do 2.9+ less then 1.5v. I'm talking 12hrs primestable.
NO IHS,no problem with 3 Ghz
Sonic Tower +120mm fan
Auto Gk ,BF2142,BF2,tonight it goes for prime...
Opteron 165 CCBBE 0617 FPMW
http://forum.pcekspert.com/showpost....8&postcount=22
model number: OSA180DAA6CD
core description: Opteron 180 - 90nm socket 939 X2
5-letter code: CCBWE
week-code: 0541
4-letter code: RPMW
CPU frequency: 2xPrime95 stable @ 2805 (255x11)
CPU voltage: 1.53
temperature (idle/load °C): system 38/41, CPU 26/40
motherboard: A8N32-SLI
cooling: Storm, 2x MCP655 pump, 2x heater cores
memory: Corsair TwinX2048 3500LL Pro (Infineon BE-5)
memory bus frequency: 255 MHz
memory timing: 3-3-2-6 1T
memory voltage: 2.8 V
HT frequency: 255 x4
power supply: Tt PurePower 680W
2xPrime95 stable
SETI tested 24/7 for months
SuperPi screenshot
Version 1.0.4.2 works fine on my A8N32-SLI ...Quote:
Originally Posted by mariosimas
http://www.cpuid.com/clockgen.php
Originally Posted by Ivan Os
I gauge stability by doing 8hours minimium to 12hours. I can boot 3ghz-3.050ghz no problem into windows but isn't stable worth a damn. I've also tried a TTBT with a 110cfm Silverstone and now on a Tuniq Tower 120 with the Silverstone.
Hey,me also.Quote:
Originally Posted by Peter949
I have been doing Orthos prime for 7,5 hours,stress CPU last night,priority 10.(2970 Mhz)
For me is something stable with minimum 1 week testing,all sorts of benchmarks,stress tests,games,encoding and no crash...
I look for my max OC for 24-hrs use not for screening...
:toast:Quote:
I do not have a long term Prime cert however it is 32m Pi stable as well as long term bench and gaming stable which was good enough for me. Once I got the ram figured out it pretty much settled right down. ;)Quote:
Originally Posted by likewhoa
How many volts for that 2.970ghz?Quote:
Startup 1,375Quote:
Vcore 1,350 x 113 %
http://img405.imageshack.us/img405/4193/voltslt3.th.jpg
But only "problem" so far i have is this:
LOOK AT CORE TEMPS PLEASE!
WTF?
http://img206.imageshack.us/img206/9241/wtfsh5.th.jpg
Originally Posted by CH33TAH
By reading what you posted, your temps of 22/45 (idle/load)....What are you using to monitor those temps? Smartguardian? Speedfan? Those proggies read from the mobo's sensor. Try using CORE TEMP and see what are your real internal temps, I will also tell you your max case temp (which should be aprox, the max safe operating temp). Even having the best air cooling, air has it's limits, no matter what, water will be better. Try checking your temps with core temp, and will take it from there. I really whish we can help you hit 3.0, you have a nice stepping there! ;)
What about them? They don't seem bad at all (besides the fact there is a huge dif. between core 0 and 1), you're almost at 3.0 ghz.Quote:
I get after 8 hours of orthos 56 c and 48 c on each core, on water, at 3.0 ghz. I haven't removed the IHS.
Take a look at your "MAX CASE TEMP", its 59c as long as you keep it down there you should be fine.
Now with the temp difference between your cores, most people say its bad IHS mounting, but so far I have removed like 4 IHS, and even doing that still have that difference (like 10 C dif. usually), so I heard this last Optys have that in common (I mean all these great steppings), so it may actually be a bad calibration in the internal diode sensor. And, since it's not an official feature of AMD (reading temps iternaly), it may be also a bug in core temp.
Hope this helps :toast:
The way I understand it is the internal sensor isn't "official" because of the calibration problems with these cores. I believe I've read AMD would address the issue in the next generation chip.Quote:
Originally Posted by jamex
The Coolest would have found a bug by now or announced a problem with the program if there was one but it's still good for relative temps ...
Hey Jamex,Quote:
I hadn't tried core temperature. I have been using ntune and speedfan and both report the same temperatures. I know that they use the motherboard monitor and are not that accurate but they still give you an idea if your CPU is overheating or not. I did, however download core temp and the temps that I saw were pretty high. Actually they are so high that I doubt that they are accurate. I would expect a 10% diff between core temo and temp from the mobo but I saw my core temp go as high as 70C during dual prime!! This is with 1.55VCORE. Does this make sense:
Originally Posted by QuietIce
Quite true, I agree with you man. Just brain storming. I believe it's more a calibration issue -rather than a bug-, because as I posted before, I removed already like 4 IHS's (1 mine and 3 friends) and -although temps did went down- the temps between cores are still off by 7 to 10 degrees. It's quite a good proggie. I trust it more than CPU temps reading from any other programs (most of them, read from external probes I guess). I found out with my DFI expert that the difference is usually 10 c degrees when using smartguardian, speedfan (although it has also readings from one of the cores), or others. Everest is good reading temps too I think.
Cheers :toast:
Holly!!! Those are too high temps!!. Try using Everest, It reads from the cores too. Wow. Have you checked if your heatsink is very well seated and making good contact with your CPU? Have you checked you are giving it the right volts? I dunno about Infinitys mobos, they should be like my expert, so I'm guessing you have in the bios, a startup vcore option, and other 2, one is in Volts (can't remember the name) and the third is in percentages. So be very carefull on those calculations and how much voltage are you actually giving it.Quote:
Other thant, what is your Gskill memory model? DFI mobos are very picky with mem settings (at least lan partys are). Maybe you can tune them, or relax them a lot and see what happens.
I would suggest removing the IHS, but I think you should leave that for last.... I haven't seen any of those last steppings doing so bad at 2.8 ghz, and at a soo high temp as yours, so must be something else.... Check if the heatsink is well mounted, other suggestion is trying the stock heatsink (the one that comes with your Opty is not bad at all for 2.8 ghz, at least has heatpipes right?), so that way you can rule out the heatsink as being the culprit.
Other than that, I see you are using a .5 multi, try to avoid doing that, sometimes Optys "don't like" half multis...
Just patience man, I hope you can spank that mutha!!
Cheers :toast:
Hello...
I need some help from all 165 CCBBE 0617 FPMW users i need to know your batches.
Write them here or send pm to me with them(and what mhz they do orthos in, also if it water or air)
Thx..
I need your also Peter949..maybe you got a bad ex or you are doing something wrong or have bad temps..
I don't know my batch but its 2.924ghz on 1.45v cpu-z 12hrs prime stable on air. Smart Guardian for whats its worth says I load at 38-40c. Idle is 28-31c.
Your temps sounds right...hmm are you stil using 500w psu thats you have in your sign?, can you check how low your +12 and +5 are in bios for me(not in widows check it in bios ), Maybe your psu is to weak...i have a friend with a 500w thats have problems to run his 148 opteron over 2.85ghz and i have run it @ 3.04ghz 24/7 before and his +12v is droping in bios(<-11.9v)Quote:
Damn i want to know your batch so i can avoid the batch thats are close to it, if it not are your psu that holding you back.
Hi; guys
How is the opteron 175 ? is it good overclock potential ?
175 has never been any better than 165/170. Higher multi can come in handy, sometimes to avoid coldbug (which is HTT related). I guess that as the 165 and 170s both have equal steppings floating around, the 175 will also have those. It's worth a shot, but you gotta be lucky because as far as I know, nobody has got a (decent) 175 right now.
