You have the 1A4T sticks from Newegg? When did you purchase them?Quote:
I got my TMSP BH last week. They actually print BH on the ICs themselves now. I wasn't too happy since I already had a nice pair of the CH which are solid performers and I was trying to go 4x512. The mixed pair seem to be pulling in different directions with regard to voltage.
I got my sticks about a month ago and they were UTT-CH, so I can't help you there, but...Quote:
Originally Posted by HousERaT
I did see a report (can't remember if it was a rep or not) that TwinMos has recently run out of AA4T and are supplying retailers with 1A4T in it's place right now.
My PC3200 TMSP from newegg came last week and they are BH-5 (says so on the chip, like already mentioned): 1A4T, 44D.
Found it, actually it's an email in post 2954 in this thread lol.
LOL how on earth can you swap it as a bad stick when its only supposed to run at 200 :rolleyes:Quote:
Originally Posted by Cranox
I know brad, I'm always bewildered by such statements/actions.
Heck, to think of it, my 2x512MB UTT-CH can only do 245MHz 2-2-2 1T stable w/3.2v ... not good enough... I'm RMA'ing them to see if I can get better lol.
:slapass:
Hell my OCZ EL 3200 Rev 2 will only do 310 @ 3-3-3-8 1T its simply not good enough LOL :DQuote:
I just got in some Twinmos utt and I have it doing 262 @ 2-3-2-6 .....For some reason it doesnt like 2-2-2- wont memtest stable with it there. I havent pushed more volts to it tho to see. Not bad so far.
Here is where I had at 265 2-2-2-6 but it wouldnt memtest.
http://img201.echo.cx/img201/8581/2651ik.th.jpg
Last week my pair came from the NewEgg east coast warehouse, this week they're coming from La Puente, California. I wonder if there is any chance for another pair of CH? BH may require less volts to go 2-2-2 but I think OCZ and Mushkin picked CH for thier PC4000 VX and Redline because of better OC potential.Quote:
Originally Posted by hovo73
Nice! on another note i noticed your x850xt modded clocks WOW!!! can you direct me the way you went with yoursQuote:
Originally Posted by Crazykooter
THe memory on the vid card isnt modded. To get that high of mem just change the trp setting in the mem config with ati tool to a 6 instead of a 5. Allow much higher mem oc without artifacts. The core is just pencil modded to 1.69 volts atm. I was gonna up it but I havent benched in 2 weeks now. I am water cooled so it makes a big diff when keeping this core cold. The 850xt gets very hot when at 690. I think if I give it 1.75 core I could get 700. Well see.Quote:
Originally Posted by bradmax57
Oh to learn the pencil mod go here.
http://www.techpowerup.com/articles/...g/voltmods/112
Yup mines watercooled too, one thing I cant quite figure which chip is which LOLQuote:
Just have to look at it for a bit and it will come to ya. I have done this to 2 cards so far and now its very simple and fast.
:toast:
I believe both the Redline and Gold VX chips are BH die. CH die memory seldom run 2-2-2-5 below 3v.Quote:
Originally Posted by gundamit
Well I just ordered a gig so I'm hoping for the 1A4T sticks. I won't cry if I get the older stuff since I already have a gig of AA4T. Then I'll have to try and run four sticks...... :D
AndyOCZ has recently posted that the VX series uses CH die while the Gold uses BH die.Quote:
The store owner is a friend of me ...Quote:
This is NOT a RMA , i just go to the store and swap the stick ( he got a few in stock )
Hmmmmmmm interesting. I thought the Gold VX were rated at 2-2-2-8 with less than 3v? Guess I was mistaken as I don't own any. My Value VX sticks won't touch 2-2-2-5 timings without at least 3.2v.Quote:
Originally Posted by FLDQUY157
I believe Duonger said that the Redline mem uses BH die? or am I wrong about that too? :p:
As far as I'm aware;
OCZ VX: = binned CH
OCZ VX Gold = binned BH
OCZ VX value = unbinned CH
Mushkin Blue = unbinned BH
Mushkin Redline = binned BH
EDIT: spelling :rolleyes:
What's the difference between binded and unbinded bh/ch?Quote:
Sorry I meant binned. Long night, last night.
binned = tested (by the end manufacturer) to run at it's rated speed.
unbinned = not tested to run at it's rated speed.
My mushkin blue aren' utt or some kind of good oc ram.
They overclock like :banana: :(.
Ordered them from pc-memory-upgrade.co.uk
What volts are you giving to them??Quote:
Originally Posted by easypanic
Wow.... you feed your TwinMOS 3.7v.... how do you cool them? :DQuote:
Originally Posted by Lord_RTKK
I have a 12cm fan blowing directly over them (it is a low noise/low CFM´s fan...)Quote:
Originally Posted by Garrett
They doesn´t get hot, only slightly warm to the touch (they only get hot with memtest for a few hours)
BTW, I don´t have them @ 3.7v for 24/7 use, because my TwinMOS SP can do 263 error free with 3.4v + 0.03v, and the increase in performance between 263 and 270 is not noticeable, so I prefer to run them at a little lower speed but a great lower voltage... ;)
