pci-e not working above 8x.
I've had a z77 extreme4 for the past few months, and the only issue i've had is that no matter what the pci-e slots won't work above 8x (nvidia 660ti). I've tried both slots, and neither work above 8x (in pci-e 2 spec in bios, or 3). I've tried at least 4 different bios and none of them correct the issues (granted running at 8x doesn't drop my performance in the slightest... just bugs me it's not running at 16x). Any thoughts?
pc specs:
i5 3570k @ 4.4ghz
corsair ram @ 2000mhz
samsung 830 SSD
nvidia 660ti
Extreme4 Z77 - GUID Issue
Hi,
Hoping someone can shed some light on this issue.
Basically im using 2 x Extreme4 Z77 motherboards with VMWare ESXi 5.1 as a test lab. The motherboards are working fine however some virtualisation networking software ( Cisco Nexus 1000v ) which i use as a virtual switch will not work in a high availabilty pair due to the fact that the motherboards have the same GUID. Other people seem to have this issue with Asrock MBs. I followed the details in the forum and its failing. Has anyone else experienced a similar issue and if so were you able to fix it.
http://forums.penny-arcade.com/discu...-a-motherboard
Thanks for your time.
J
