i just got an ECS black 790GX AM3 mobo wonder how it clocks compared to my asus M4A78T-e going to test them both on DICE this weekend hopefully
0913FPMW 90149
Priming now at 3.72Ghz 1.42V | 2600Mhz NB @ 1.30V | M3A79-T 2x 2GB Crucial Ballistix Tracer 800 C4 @ 1066Mhz 5-5-5-15 1.95V
And here it goes
http://i41.tinypic.com/24edt1t.jpg
http://i40.tinypic.com/2ryqdes.jpg
http://service.futuremark.com/compare?3dm06=11008005
last month ago .....:D:D I will try this weeks with ASUS CROSSHAIR III
HARDWARE SETUP :
PHENOM II 955 BE 0911 APMW
DRAGON F1EE + EXTENSION
DFI LP DK 790GX JR M3H5 DDR3
ADATA X SERIES PC 1600
ASUS HD 4870X2 TOP
ANTEC SIGNATURE 850 WATT
http://img35.imageshack.us/img35/1170/img0155f.jpg
http://valid.canardpc.com/show_oc.php?id=573873
http://img36.imageshack.us/img36/7084/21776249.jpg
Single core? Or not enough volts....two reasons for the rejected.....but nice going.
Now that i'm not under the constraints of a review and i appear to have some free time......I am really gonna let this cpu of mine rip ;)
Hey Chew*, I accidently got a 955BE this week, what do you think? Air results in the skeleton case.
http://3800z24.info/Phenom/Skeleton/955-4ghz-cine.JPG
http://3800z24.info/Phenom/Skeleton/...955BE-test.JPG
Looks like the newer batches are improving, hows it do in prime blend?
^^^ I was wondering about that too after seeing the results from the X2 550's...
I've yet to see a 955 with a week code later than 0919, while most of the 550's are in the 092x range. You would think the 955's have to binned higher than the X2's.... :)
try Cinebench R64 ,-)
I am going to order some thermal paste so I can put this under my water setup. Any ides of what to get? I don't like the heat the stock cooler is showing and would like to get it off ASAP :p:.
I just did some stock volts stable test first. I am running 3.8 1.45v now. I will do 4ghz next.
http://3800z24.info/Phenom/Skeleton/...6-Intelx15.JPG
http://3800z24.info/Phenom/Skeleton/...PrimeBlend.JPG
We should get some compares to 965 results up here!
i think, x4 965 is a bit better for OC, x4 955 ended ussually between 3.7-3.85 Ghz and x4 965 think up to 3.9 GHz (with AIR)
wel, you should look at lower end(3.7ghz). for 965 it would be 3.9ghz :) and that is something. and even with 50mhz it is something for the same cpu with volt bump :)
3d on phase change on an average chip.......
http://members.cox.net/hoobahans/955...%20Xfire10.JPG
3d on phase after binning 10 chips..........all other chips could not break 4.4g
I might add this chip bombed out on ln2, lack of voltage tolerance.
http://chew.ln2cooling.com/qdig-file...%20955%202.JPG
3d on phase with the first 965 BE retail part I have tested......have not tested others yet, this was also on vista..........versus the above chips only on XP.
Chip #3
http://chew.ln2cooling.com/qdig-file...%20965%202.jpg
2 more for the compare chip #3 is the last shot in above post.
Chip #2
http://chew.ln2cooling.com/qdig-file...20chip%202.jpg
This is Chip #1
http://chew.ln2cooling.com/qdig-file...20chip%203.jpg
I thought I would add this for you simon let me know if your seeing what i'm seeing.
Chip #3
http://chew.ln2cooling.com/qdig-file...2m%20phase.jpg
Chip #2
Chip #1
Got another chip done today as well......well sort of, 1am now.....
We will call this "review chip" #1
http://chew.ln2cooling.com/qdig-file...20chip%201.jpg
Here's another one of these to add some food for thought, same chip.
1 more to go, need some sleep..........
