Originally Posted by
MaximumPig
I have that cooler in my UD3R and it fits nicely, even with the 2nd fan added. no interference from the heatsinks around the CPU. However with that cooler make sure you have the fans pointing the right way because you need to unscrew the whole thing from the motherboard if you need to switch a fan, and that means taking out the whole mobo if you can't get at the underside of it with it in the case. Also there's a set of screws that actually turn the wrong way (turn left to tighten, not right)--you'll see why when you put the thing together.
