550FSB without really trying hard
That's the fan I put on the backplate cpu cooler, it comes with the Thermalright IFX-14 :p:
http://img238.imageshack.us/img238/8605/ifx142uq4.jpg
I'm curious, what is the latest BIOS for the Rampage Formula? Official or Beta. I thought it was 0219 official, but I have seen references to newer ones?
True, there is a 0308 for a while now. Found here on the Asus Forum: http://vip.asus.com/forum/view.aspx?...age=1&count=37
But it's a bit shady and has an S3 suspend issue :shrug:
Hmm 0401 out....: http://vip.asus.com/forum/view.aspx?...Language=en-us
Any improvements, 0219 running flawless here.
I am thinking about getting this X48 Rampage Forumla board. First I wanted to go for DDR3, but price for good DDR3 bricks are just way to high for me.
So I am thinking about setup like this one>
CORSAIR Dominator TWIN2X8500C5DF 2048MB, DDR2, 2x1GB(KIT), DHX, E.P.P, with FAN (TWIN2X2048-8500C5DF)
INTEL E8500 C2D PROCESSOR 3.16G 6MB 1333MHZ FSB (EU80570PJ0876M)
I am just wondering how easy it will be to overclock E8500 to 9.5x425 4037.5mhz on this board?
And if I need to go for better memory like 1200mhz / PC9600. And what are the benefits if there is any?
How are you guys cooling the chipset on this board?
Just some fans on the provided dissy or second market stuff like TR?
Rampage Are The Best :up::woot:
BTW Guys found a Intel X48 chipset driver on the MSI website for the X48C Platinum.
You can download it here: http://global.msi.com.tw/index.php?f...1&prod_no=1393
0401 has made official. Any improvements? They say it should improve memory compatibility.
Pll 1.50V,SB : 1.075V,Vfsb 1.44V,NB: 1.75V,CPU GTL : 0.67x,NB GTL : 0.63x,PL9,333 strap,mem 1/1 - 5-5-5-5.
the NB without active cooling (~62C) and the 8500 on air...i stopped at 585...bios 0219..it came out from a 10' search..
http://img375.imageshack.us/img375/8505/1mfsbny9.jpg
Well done !!! See how easy it was ? ;)
i`ll keep it for my self....hehehehehe
first time i`m glad to see 62C out of the NB....with 25-30C do you think it will get me 600??
I am using 0401 now. I don't see much change in my case.
Apparently I can boot at 4GHz a bit more easily but I need to use this rig now so I don't have time for long stability tests.
Just tried 1.42 FSB VTT at 3.8GHz but it failed on OCCT rapidly.
It's safe to upgrade to 0401 so: you will have at least the same overclocking results.
BTW: grats to those people reaching 3.8GHz with safe CPU/VTT voltages. I am jealous ;)
And this Rampage gave me faith back in Asus. I was about to give up with all the bad P35 experiences.
Thank you Xelation for the X48 chipset drivers link !
I'm also using 0401 official, I don't notice much difference. Have not really tested yet though.
