The stock vGPU on these is 1.1v, I wouldn't adjust it to 1.4 off the bat as a "safe" voltage if I were you :). You can cause damage to the chip, and with these, you can't just lower it back down to fix it like with a CPU usually. You will *definitely* need a beefy after-market cooler for a voltmod on these, the stock cooler can handle some overclocking but runs borderline scorching when doing so, let alone volt-modded. The HR03 would be an excellent cooler (make sure it's the NON-plus version, the plus one *doesn't mount* on these cards), just be aware it takes up a few slots. I'm personally trying a pair of Thermaltake ND1's, which are coming in with my two cards tomorrow:
Picture of it mounted on a 7900GT (Thermaltake ND1):
http://img463.imageshack.us/img463/4...1062xs1wf3.jpg
These should cool well for me :D, assuming they fit (which it looks like they will, but I can confirm tomorrow).
