Originally Posted by
BLunTSmoKeR
Also, at the start of last week just before I took my build apart so that I could RMA the motherboard, the first DIMM channel appeared to die on me, as the system would only pickup 2 out of the 3 RAM modules that I had installed, at first I thought one of my modules had died, so I tried out my 3GB set and it would only pickup 2GB of RAM.. so I tried just running the system with 1 stick in the first white slot, and another in the 2nd white slot, and it would only see 1 stick, so I shutdown again, and moved the stick from the 1st white slot into the 3rd white slot and started the PC up and this time it picked up both sticks of RAM...
I then tried booting the system with just one module installed in the first white slot but it wouldn't even POST...
I then tried running my 6GB set with 1 module in the 2nd blue slot, 1 in the 2nd white slot, and the other 1 in the 3rd white slot, and booted up, this time it recognized all 6GB but it was only running in dual channel obviously...
