got it
1GB PC2-6400
DDR2-800MHz = CAS 3-3-3-8
GX22GB6400PDC
Voltage 2.4v
got it
1GB PC2-6400
GX22GB6400PDC
Voltage 2.4v
Go to the main bios screen and hit Ctrl and F1 at the same time. Then go to the motherboard intelligent tweaker page and you will see the memory voltages. Set the voltage as per your brand. Save the settings and then cold boot (power off and on). Now when you check cpuz it will probably show the right memory and spd.Quote:
Originally Posted by lwj5
Edit....this is what I found with a simple google search.
The memory itself is designed to run at 2.0V or higher depending upon the latencies selected. GEIL actually rates this memory at 2.4V for 3-4-3-8 operation at DDR2-800 although we have not required voltages above 2.2V at this setting.
Also this.... http://www.anandtech.com/showdoc.aspx?i=2854&p=2
Same here. The first boot of the day never works. The BIOS always resets itself. Warm reboots, Priming, gaming all work fine. I just can't get the system to cold boot with my overclock.Quote:
Originally Posted by t800
Don't just focus on your cpu... Do some orthos at large and see how it goes. I used to have the same problem when I set my vdimm to default which is 1.8v. Damn power cycle and I hate those days when I got my system. As I start playing around with the vdimm and timings, I'm so in love with my pc now lol!
thats why i never turn off my pc anymore , cause this ds3 damn thing
Any news as to when the new DS4 BIOS will be out? I'm looking forward to getting to use my Kingston 8500 ram at it's rated speed or above.
According to anandtech forum, gary key said ds3 f8 final will be out this week.
I know but every week we heard "this week is week of Micron D9" but past more than 4 week and any new BIOS even Beta!!Quote:
eXceededgoku
HamidFULL calm down man , we already have news from Bingo and he is actively trying to get us the new bios as quickly as possible. It might come out at the end of the week at the earliest...
JPH1589 : use this for stability test --> www.ultimatebootcd.com
kimandsally no new BIOS over F7b for DS4 I also waiting ... too long!
Patience is a virtue;)Quote:
Originally Posted by HamidFULL
DQ6 / F8b running stable 450x8 3.6Ghz @1.5125v (1.46v) 6 6 6 24 with G.Skill HZ
It's a little too hot for my liking, peaking at 70c (Core according to Everest) during dual prime 95 lge/sml ffts.
I booted but failed prime within minutes at 460 but at that time my ram timings were tighter at 5 5 5 18 and I've messed with voltages since then. I'll try 460 again with current settings.
Can someone help me though, what is appropriate setting to mess with when the system boots but doesn't show any video i.e., blank screen, but it's obviously running? I think it's related to FSB Freq. which I've set at 100 for now iirc. I'm pretty sure that when I set 105 or anything other than 100 this symptom presents itself. I haven't changed PCI Overvoltage from Normal.
OK......I promise I wasn't smoking anything before I typed this.
As a part of my testing of F8i this afternoon, I was testing my memory overclocking. My memory has run at DDR904 on another motherboard so I wanted to see how close I could get.
I must have been smoking something afterall.
Not too sure if this is impressive, but I hit 500Mhz 5-4-4 with 4 x 1GB of Fatbody D9 with F8i on a DS3.
8 x 400Mhz on the CPU, I could only wish that it was 1:1 :D
However, my board craps out at 480Mhz with +0.2V, and +0.3V won't even boot, even with cool 7C Canadian air blowing on it.
Hopefully, there will be some improvements in the final F8 release.
BTW, has anyone else noticed that memory bandwith is better at 450Mhz than at 455Mhz? This is 1:1 with a 8X multiplier :confused:
The problem is the F8b beta for the DQ6 is very immature, there is a problem with overclocking and the Watch Clock Time Out.
I was also able to set FSB to 425x8, but upon shutting down and restarting the PC just hangs on POST, it won't save the overclock settings. Thus it's not wise to have an overclock with F8b, default settings are fine.
Wait until the bios matures, i also thought the problem was related to the PCI-E frequency, it's not...it's more technical.
"Watch Clock Time Out"?
Like i said, it's technical. A new beta spin is supposed to come later in the week.
lwj5, what you are saying is common for Geil RAM. Check their website. All their RAM is read as 5-5-5-15 DDR2-667 when you first boot up. You have to go into the BIOS settings and manually set the memory timings of the actual RAM.
I would suggest you try memory overvoltage of +0.3 tho you may get away with less if running at 800 and 5-5-5-15
As mentioned above, to get to the settings you need to boot into bios and from the main screen press CTRL+F1 then go into the MB Intelligent Tweaker settings.
The settings are there
He has been told that at least 6 times on 3 different forums in 4 different threads. He doesnt' like the answer, so he just keeps asking LOL!!Quote:
Originally Posted by therat
Unfortunately for him then, the truth isn't going to change :DQuote:
??? I only post on 2 diff forums and 1 thread each, what r u talking about
This r my bios settings
System Memory Multipier 2.66
Memory Fre(MHz) 798
Cas Latency 3
RAS# To CAS# Delay 3
" " Precharge 3
Precharge Delay (tRAS) 8
ACT to ACT Delay Auto
Rank Write To Read Delay Auto
Write To Precharge Delay Auto
Refresh To ACT Delay 0
Read To Precharge Delay Auto
DDR2 Overvoltage +0.3V
i still dont get PC2-6400
It will never show DDR2-800. That's how they are designed by Geil.Quote:
Mine are exactly the same (tho different timings).
cheers
I'll 2nd that.Quote:
Originally Posted by irev210
Tag Bagged!
If I get this wrong I'm sure someone will whack me!:DQuote:
I was going to say it's apples vs oranges but it's really memory speed vs data speed.
798 ~ 800
800MHz * 8 = 6400 MB/s
64bits of data can be transferred on each clock cycle. That's the same as 8 bytes. So
DDR2 800 * 8 = PC2-6400
I don't think I've seen PC2-xxxx referenced by GB in the BIOS, manual, etc.
I just received F8c beta for the DQ6, not flashed as yet. Observations later.
:eek: thats crazy talk!, you'd need some high speed fan or watering cooling on the RAM for that voltage.Quote:
Originally Posted by Renasc
Dangerden anyone?
New version of EasyTune 5:
http://www.gigabyte.com.tw/Support/M...lity&FileID=49
P965 shootout feat. DS3+DQ6:
http://www.tweaktown.com/articles/99...ion/index.html
If anyone is interested/has the Neatgear DG834PN RangeMax - new firmware out, support for WPA2 added...woot!
http://kbserver.netgear.com/release_notes/D103021.asp
