I managed to snag a UD9 on Newegg OB for $370 a few minutes ago. Will definitely compare these two!
http://i747.photobucket.com/albums/x...xx/shhhiii.png
Yeah it actually happened to me as I have an EX58-UD4P.
Apparently it was fixed on the X58A series.
hello,
i have tryed 2 cpus and both on r3e are stuck at 219-220 bclk....cannot boot over that wall....
i read that other guys had this issue...any solution ?
i don't think is important 2d or 3d when trying max bclk :)
i have multi at x15
i tryed pci-ex 100~120 with no success
for max you would have to use slowmode
was that on any cpu ?
im at 250 blck right now but in slowmode :(
http://valid.canardpc.com/show_oc.php?id=1406814
yes you have right =) Cuz
slowmode enable and 250 bclk give Qpi at 4000mhz+
slowmode disable and 250 bclk give 5000mhz at Qpi link
here is mine 257 Bclk and slowmode enable and qpi at 4117mhz and taken by bios 1005
http://valid.canardpc.com/show_oc.php?id=1386064
Interesting.
Slow mode at 266 still gives me QPI much lower than 4GHz.
Here's mine at 266 BCLK and 3200MHz QPI:
http://valid.canardpc.com/cache/screenshot/1380778.png
EDIT: BIOS 0878
What is maximum safe PCI-E for benching?
my cooler is at its limit. :( just 3x 120mm rads. It all fits neatly in my PC-A10B though!
http://sphotos.ak.fbcdn.net/hphotos-..._6041045_n.jpg
It can get very hot if you get the leak in the cooling system when you play games...
http://img844.imageshack.us/img844/9739/qpdl9.jpg
my lovely I930 is still alive, using it now...
I have no idea. Maybe slow mode is different with Gulftown? Can you post a CPU-Z shot?
