You ever get those screens for that 4050mhz shot?
hey, Grn ?
are these the ram sticks you have ??
http://www.bestbuy.com/site/olspage....=1196470792007
(model: TWIN2X2048-8500C5D)
since i have a 500$ bestbuy gift card, i'm looking for some different ram... im just not happy with my crucial's anymore..
how would you rate them?
Ahhh, that post. I thought you meant the AFUDOS ES posts...? :D
http://i48.photobucket.com/albums/f2...cture005-2.jpg
http://i48.photobucket.com/albums/f2...Picture006.jpg
http://i48.photobucket.com/albums/f2...Picture007.jpg
http://i48.photobucket.com/albums/f2...Picture008.jpg
that should do it. lowest possible voltage settings to be be 8 hours prime stable small ffts and memtest for 4 hours for my particular rig:up:
my quad is LOVING the higher gtl... wish it would go to 80 though
Sick, thanks for the update :)
I will let you know how I fair with that heh.
Is GTL dangerous at all or is it merely a 'setting' that doesn't affect temps or possibly damage any components? I have it on auto and can't get to 3.7 from my 3.6 OC even if I up all my voltages by 3 clicks. Should I just max my GTL or what?
Did you guys ever find a version that allows you to flash back? I PM'd Zen just now, but this MIGHT be one that could work, I have a P5K deluxe so I am not even keen to what you guys are trying to accomplish....
This might, or might not, be a genuine find, but just wanted to help the brothers out....
http://forums.mydigitallife.info/sho...postcount=3944
Please investigate if this is the real deal, and apologies if you have already solved the issue! (too lazy to read through all the pages in the thread)....
-Jeeka
i used the 907 as the base for a bios mod BEFORE i found the es version of afudos in an attempt to get back with the tools we had available at the time. anyways to put it short it didnt work and so now we all use afudos. if we could, please kill this subject as it is confusing everyone here but me.
Well ... if I try to flash from Rampage to Maximus using bios 1004 I get a "bootblock corrupted" message and AFU236U exits. If I flash using bios 907 everything is fine.
I haven't tried this with the older 226ES version of AFUDOS.
This might simply be the case of a beta bios not containing a complete bootblock.
Sweet. I love the Rampage BIOS options for memory. I'm now running @ 440x9 on Air. I still have some instability but I'm working it out slowly. Once I can nail this setting down I'm going to try for 4ghz+ being 444 FSB+. I've been thinking of running a small WC loop just for the NB to see if I can't get it's temps more under control. I'm worried that I might end up going crazy and build a whole WC rig and use DC200 for the coolant. I've had a few gallons sitting around for just the job. :) Thanks for all the work guys.
alright.... what ram would you guys go with.... i have to buy it from bestbuy; unfortunately :/
http://www.bestbuy.com/site/olspage....d=abcat0506001
Out of that selection, the 1066 dominators would be the best I'd say
