Originally Posted by Lestat
1)
after flashing you need to go back and turn raid ON for the appropriate hard drive ports
2)
put the boot order of the hard drives in proper order.
the different nvraid roms dont make this happen. its a setting in the bios that you have wrong. although a bad nvraid rom could do it yes,, but i dont think thats the problem.
use the 1.36r4 modded bios or the 1.8 official from msi both are good.
Also the Boot order you need to make correct and also the Hard drive boot order.
It says error loading operating system becuase 1) its looking at the wrong hard drive.
2) its looking at your raid hard drives but they are not raid so it can not load windows properly
its a simple fix.
also you need to use a large string of switches with the flash i cant remember what they are and im at work so i cant tell you what they are but search this thread ive posted them several times, also sideeffect and others know what they are so wait to se eif they reply.
the fix is simple just hang tight...
also the nvraid doesnt like being messed with you have to delete the raid and choose clear data,, then reboot, then go back and make the raid again. then load up the xp cd and load windows.
you added an edit and im not sure i understand it but i highly doubt the MBR of the disk is bad unless the rAID is still intact, you must delete the raid vbia the nvraid setup menu.
