omg Ridney,,,, just omg...
My baby. Not a great shot..poor lighting. Canon EF 70-200mm f/4L IS USM w/ Sigma APO 2x DG Teleconverter.
http://farm5.static.flickr.com/4025/...a12890cf_b.jpg
@100%
-Camera: Canon EOS Rebel XS(1000D)
-Exposure: 1/6
-Aperture: f/5.6
-Focal Length:46 mm
-ISO Speed: 100
-Exposure Bias: 0 EV
-Flash: Off, Did not fire
-Lens: Canon EF-S 18-55mm f/3.5-5.6 IS
thanks metric and lestat, i could not afford a tilt-shift so i just resorted to online post process :D
very nice lens you got there 1tanker, i'm currently debating of getting that lens or the 24-105 since i find my 17-55 to be a little bit short to my liking
Thanks ridney.:) A few considerations(which you've likely already thought of).You've already got wide-medium angle covered with your 17-55, so a 24-105 would overlap a lot of your focal-lengths. With the 70-200..it's still a nice range and you would only have a void from 55-70, which isn't much of an issue..one lens or the other will get you that 15mm by taking a few steps forward or back. Here in Canada, the 70-200 is $1200 CAD, and the 24-105 is $1270CAD..and the 24-105 is also slower than your 17-55. To top off the price issue, the 24-105 takes 77mm filters, vs. the 70-200's 67mm...costing a few bucks more for each filter. ;) I guess the 2 main issues are whether you plan to go FF down the road, and if you really want/need 200mm FL. :shrug: GL
Edit: I guess the filter size issue isn't an issue, as your 17-55 uses that size and you could share them.
http://i970.photobucket.com/albums/a...g?t=1262015496
Camera Model: Canon EOS DIGITAL REBEL XTi
Date Taken: 2009:11:26 12:37:44
Exposure Time: 1/125 sec.
Aperture Value: 4.00 EV (f/4.0)
ISO Speed Rating: 200
Metering Mode: Pattern
Exposure Program: Normal program
Focal Length: 60.0 mm
weevil... Canon 60mm Macro?
http://farm3.static.flickr.com/2495/...b6764630ab.jpg
Camera Model: nikon d200
Exposure Time: 1/40 sec.
Aperture Value: 1.8f
ISO Speed Rating: 640
Exposure Program: Aperture priority
Focal Length: 35mm
more toys have arrived.
toy #1 - Yashika Yashinon-DS 50mm F/1.4, M42 screw mount (pictured)
toy #2 - Sears M42 135mm F/2.8, M42 screw mount (used to take the picture)
http://stinky.no-ip.biz/photo/conver...3335372e6a7067
Canon 40D
Sears 135mm F/2.8 @ F/8
ISO-100
exposure - 3 seconds
Lestat can you set aperture manually with any of those lenses?
I could really use a ~35mm fast lens with MF & manual aperture for my 500D when recording videos since I can't control the depth of field using the camera settings
http://i970.photobucket.com/albums/a...g?t=1262099229
Date Taken: 2008:02:08 16:09:21
Exposure Time: 1/160 sec.
Aperture Value: 5.66 EV (f/7.1)
ISO Speed Rating: 400
Flash Fired: Flash did not fire, compulsory flash mode.
Focal Length: 83.0 mm
http://www.xdevs.com/images/ny2010/panoram_2ka_wsx.jpg
There are much more photos available from yesterday too :)
Camera Model: Nikon D200 on tripod
Lens: Nikkor 20/2.8
Date Taken: 2009:12:28 03:40 AM
Exposure Time: 30 sec.
Aperture Value: f/8 afair
ISO Speed Rating: 100
Focal Length: 20.0 mm
you bet. the 50mm will go to F/16 and the 135mm will go to F/22
but M42 lenses have a little push pin on the rear of the lens that must be pressed in in order to allow the iris to open and close when you change the f-stop.
most M42 adapters to not hold that pin in, so you have to make your own way to hold the pin in, i just use superglue, push the pin in, put a little around the pin and hold it until its dry enough to stay, and then let it dry fully before i use it.
there are some lenses with an auto/manual switch and those ones do not require the pin to be pushed in, just flip the switch and you can change f-stop on the fly.
the 135mm lens is like that where as all my other M42 lenses must have the pin held down.
i'll get a picture for you tonight when i get home.
http://stinky.no-ip.biz/photo/conver...3835392e6a7067
canon XSi
Yashika 50mm F/1.4
ISO-100
1/13th sec.
http://farm5.static.flickr.com/4034/...44247ebd07.jpg
Camera: Canon 50D
ISO: 100
Shutter: --
Aperture: f/1.2
Exposure Bias: 0
Lens: Nikkor 50mm f/1.2
http://i970.photobucket.com/albums/a...g?t=1262187695
Date Taken: 2007:12:22 14:02:14
Exposure Time: 1/320 sec.
Aperture Value: 4.97 EV (f/5.6)
Exposure Program: Portrait mode (for closeup photos with the background out of focus)
Focal Length: 300.0 mm
http://farm5.static.flickr.com/4068/...ba2404e8_b.jpg
Camera: Nikon D40
Focal Length: 10 mm
ISO Speed: 200
Aperature & Shutter speed: Variable (HDR)
Sigma 10-20 EX
Beautiful ANP
http://lh6.ggpht.com/_7BFkwLFb9q0/Sz...0Surf2.png.jpg
Took this the other day. First time using a telephoto :D
Camera: Canon Rebel XS
ISO: 100
Aperture Value: F/5.6
Air Wick anyone? lol
http://farm5.static.flickr.com/4050/...83466648_b.jpg
Cam. : Canon Rebel EOS XSi
F-Stop : f/4.5
Exposure Time : 1/2 sec.
ISO : 100
Exposure bias : 0 step
F-length : 105mm
Flash : No
Mode : Manual
http://farm3.static.flickr.com/2768/...1568fd7d_b.jpg
If you check the full-size view, you can see a decent-sized snowflake inside the leaf...looks pretty good.
100% view
- Canon EOS Rebel XS
- Exp-1/320
- Aperture-f/5.6
- Focal Length-100mm
- ISO-100
- Flash-No
- Exp. Comp.- +2/3 EV
- Canon EF 100mm f/2.8 Macro USM
http://i970.photobucket.com/albums/a...g?t=1262246679
Date Taken: 2008:03:30 09:49:59
Exposure Time: 1/500 sec.
Aperture Value: 6.64 EV (f/10.0)
Focal Length: 75.0 mm
http://farm5.static.flickr.com/4056/...0395bd5c_b.jpg
E/30
F/6.3
10mm
ISO200
