thanks a-grey i'll give it a shot later in the week
Did you end up getting your ram to run higher than 1200mhz, and whats your final thoughts on bios 902?
is there any benefit going to bios 902 from 803??
I don't think so.
EDIT: A-Grey what mch voltage do you need to stabilize 400fsb, 600mem 5-5-5-15 trd6? Could you please check it for me? Looks like I need 1.45v what looks pretty much for me.
Has anyone tried removing the ROG logo from the stock SB heatsink? Is it even possible? It looks like it's severely hindering the SB's heat dissipation.
I've been running a few tests and I didn't need more voltage on the MCH to run LinX for a few passes stable.
I did a test with CPU Clock Skew Delayed 200ps and NB Clock Skew Delayed 100ps. It stayed stable but there was no need to dial in a delay.
I tryed with CPU Clock Skew and NB Clock Skew on Auto and everything was running smooth.
I have to say that I only did 3 passes in LinX but I think it should be enough to see if it's really possible with lower voltage.
The 266MHz strap isn't the problem. It must be something else. Perhaps your MCH temp is to high (my MCH temp was 34° Celsius during the test) or you need that high voltage to keep your memory stable at 1200MHz.
You could try with your memory running at default speed and see if that would help to keep it stable with lower voltage. When that doesn't work try to find a way to lower the MCH temp to see if that's the problem.
I've removed 2 of them with a screwdriver no problem at all.:up:
I've just been testing out my system with UT2004+P95 in blend and the problem i have is that P95 keeps failing.
As you can see above i am stable for 5hrs on large ffts and 5hrs on small fft's as well as 25 passes of linx. I should also say that the memory has passed 8 tests of Memtest86+ test no5 as well as 400% of HCI memtest.
i have tried increasing the FSB termination.
1.30V lasted 5hrs
1.32V lasted about 2hrs
1.34V lasted about 2hrs
after seeing this i decided to try lowering FSB termination to see if higher wasn't better
1.26V lasted 1hr
I would appreciate any advice as to what is causing the instability with P95 and UT2004 or do i just need to play with FSBterm some more????
this is the log for the test (P95 blend + UT2004 in 64-bit) with FSBterm at 1.34V (known stable in Linx)
[Sat Aug 22 13:36:16 2009]
Self-test 1024K passed!
Self-test 8K passed!
[Sat Aug 22 13:53:18 2009]
Self-test 10K passed!
[Sat Aug 22 14:08:34 2009]
Self-test 896K passed!
[Sat Aug 22 14:23:32 2009]
FATAL ERROR: Rounding was 0.5, expected less than 0.4
Hardware failure detected, consult stress.txt file.
Self-test 768K passed!
I assume that means it failed in LargeFFt's
will do thanks A-grey, and thats awesome news hope it goes well
Increasing the NB voltage by 1 step to 1.39V worked a treat. I'm stable now for 10hrs with FSB termination at 1.30V. When i have time i'll try to lower the FSB termination.
http://img8.imageshack.us/img8/5484/p95ut2004jpg.th.jpg
Can anyone confirm hr-09 + rampage formula compatybility list, link: http://www.thermalright.com/new_a_pa.../05-09-mcl.htm?
A-Grey can you make a photo of how does it look mounted on mobo?
There are a few pictures of my system on the ASUS Rampage Formula forum. They aren't the best quality pictures but I don't have a good digital camera.
You can find them here: http://vip.asus.com/forum/view.aspx?...e=en-us&page=2
Is there any possibility to mod 802 bios so by default it would be setting the highest possible tREF (16k) instead of 3120?
