Originally Posted by
jonny_ftm
Old myth, some believe in it, never seen a definite test
The VID should be measured at idle, on default settings. It is the lowest vcore intel built in the CPU internal settings that the CPU could run.
Theorically, the lowest it is, the better OC headroom you have
My Q6600 G0 has a VID of 1.16v, so theorically, I could reach higher OC before increasing the vcore than a VID of 1.21 (I can't test, since I'm FSB limited)
Personally, I'm not convinced as my chip needs 1.39 vcore on load for 3.51GHz, not a world record... despite my VID
