Can you create a link to CPUZ 1.28.6 as my current one are 1.28. TQQuote:
Originally Posted by BitpowerPM
Nice work. But I only manage to push my TwinMos SP to 250Mhz (stable) @ 3.5v (2-2-2-2). Prime95 stable for hours. But when I tweak to 255Mhz @3.5v (2-2-2-2), there was a few errors when running memtest86 v 1.51. But it would failed Prime 95 in within 1 minute. (ya. 1 MINUTE only). Now, I am doing burn-in by running test 5# (memtest86). Actually, I had burn-in for more than 10 hours and it is still no go. I don't know what is wrong. May I know did you do some burn-in for your RAM to reach 265MHz. I did pump the vdimm from 3.6v to 4v on my DFI NF4, but giving more voltage would give me more errors in memtest86.
Why are you running 2-2-2-2?Quote:
Originally Posted by longsiew
http://users.skynet.be/pt1t/Twinmos/TwinmosSP275.PNG
2* 512Mo Twinmos SP PC3500
Real vdimm = 3.89v
Spi 32M passed @ 268mhz
I m burning it to win some mhz in stability.
be very carefull, DFI NF4 reports 0.1 (yes it's 0.1) volts less in BIOS + smartguardian, this means you have about 3.92 VDimmQuote:
Can the ram die from high voltage? I need 3.75v to run 250 on my old kingston CH-5, or 3.48v to run 245.
Attn UK folks!
TwinMOS S.Premium PC3500 BH-5 have gone down from £48 to £44 with plenty of stock...
http://www.komplett.co.uk/k/ki.asp?sku=308282
TwinMOS S.Premium PC3200 CH-5 still at £48
http://www.komplett.co.uk/k/ki.asp?sku=308281
And strangely, a PC3200 variant of the Speed Premium BH-5 have appeared...
http://www.komplett.co.uk/k/ki.asp?sku=309097 :confused:
Originally Posted by mitgsx
ofcourse RAM can die, but you minimize chances with good cooling.
I would stick to 245Mhz for 24/7 and 250 for benches 3.75 is a lot of Vdimm for 24/7.
Thanks for the tip esdee!
Is there anywhere to purchase the twinmos SP pc3500 here in the US?
you are welcome,
sorry i don't know about SP in the US, but i think twinmos will release BH5 under the twinmos twinster model. So maybe it's a good idea to wait a couple of weeks
how on earth you guys get so high scores grrrrrrrrrrrrrrrr
try to tighten your timmings they are REALLY loose :stick:Quote:
Originally Posted by anilyy
They're AA4T with almost matching serial numbers.
http://members.shaw.ca/comic-kaze/20...le/twinmos.jpg
I found a place that sells twinmos pc3700:
0313D
TMD7608F8E43B
How will these perform?
I am trying as many timing as possible. If possible I also want to run in 1-1-1-1 or 0-0-0-0 ( I know that's imposible) Now I am running at 2-2-2-6 @ 3.6v. I think my TwinMos SP like high voltage. Last 2 days ago I was running 2-2-2-2 @ 3.5V but it would fail Prime 95 within 1 minute. Now, at 3.6v I managed to run Prime 95 within 9 minutes or more. My goal is to run at 260MHz (DDR 520) at 2-2-2-2 @ whatever voltage. Now I am burn-in my ram at DDR 510 at 3.6v using memtest86 v1.51. One thing I noticed is that when I cool my RAM using 90mm fan over them, there is less errors in memtest (DDR510). If i removed the fan, there is ton of errors. So, heat is the one hinder my RAM in my case. Hopefuly I can get my blow hole done on my case and put a 120mm fan and blow directly to my RAM. (short of money now, has to wait for another pay cheque). My wife also told me that there will be PC Fair in Singapore mid of May 2005. Hopefuly I can get some cheap and decent overclocking RAMQuote:
Originally Posted by Soulburner
Well my 3200 SP arrived today, unfortunatly my booster didnt, the delivery guy just this second came i signed i opend the parcel and it was a fecking floppy drive, looked at who it to and its someone else, the delevery guy had deliverd the wrong parcel and now im hoping that when he comes to deliver the parcel i have he will relise his mistake and get back to me.
anyway my Speed premium, well it SUCKS at 2.5 2 2 5 1t 200mhz i get around 300,000 errors in mem test test5, and i cant seem to get only 1 stick working at a time, my mb is a neo 2 platinum with the 1.36b bios with a 3000winny, any thoughts??
the delivery guy has just come back with the correct parcel im now going to see how these sticks like 3.3v
Whats the codes on your sticksQuote:
2-2-2-2 even if it can prime for 10hours it might still result in reduced performance compared to 2-2-2-5 do some benchmarks to find out whats best for you :toast:
i think that they both end in 44d just got my booster in and calibrated and im just installing some logitech drivers (got a mx1000 as well) i will check the full code after this.
oh and the sticks are fine to boot at their defult settings, 200mhz, 2.5 3 3 8 @2.7v ive got win mem test running whyle i sort out my mouse and it seems fine, no errors.
ok here are the codes on the sticks
05064 -date
TMD7608F8E44D
oh and it turned out that all it needed was some love in the form of 3.4v now in windows at 240mhz 2225, going to suiside in clockgen to give me an idea at waht point they foul up at. oh and 250mhz didnt post.
you did drop your ht multiplier?Quote:
ya i droped the ht, well going for broke on the suiside the comp crashed at 250, and found that errors start in memtest at 245 so some breaking in should take me to 250@3.4v, its no 270 1.5-2-2-5 but it could be worse, out of interest how many more mhz does one genraly earn from a decent breaking in.
mine did 255 straight off but after a bit of burn in do 263 with no errors, can run pc all day long tho with out any probs as high as 270 or even 275Quote:
Ordered my SP3500 from komplett.co.uk last week and it should be getting here tonight... been reading this thread for a while certainly kept me busy.
Its going in to a nf7-s with a mobile XP2500, my only drawback is the fact i top out at 3V... (well untill i can afford to buy myself a venice and new motherboard :clap: )
