my board bios/tweak it-no difference
Vtt 1.4v-1.35v real with DMM
hi folks, i'm wondering about the Xeons Processor, so the question is: Asus has released an official BIOS for these processors?
TIA
Hey guys, Wanted to ask if the top black PCIe x1 can be used with any other pcie sound card ?
Is it necessary to replace the tim under the heatpipe chipset cooling assembly? Or is it good enough out of the box?
.., been away for a while.., sorry for simple question...
Any new revision out on this board...?
Bclk stop fixed..?
Maybe I can find it amongs those 115 pages.., but maybe some kind soul just can write a few words.. :-)
Okay.., thx for swift answer! :-)
What is non-lethal?
PCIE frequency - ?
I'm stuck at 218 bclk.
I've tried all sorts of various voltages and timings with no luck.
These are my settings so far just for seeing how far it'll top out at. Haven't primed yet.
AI overclock - Manual
OC from CPU level up - A
OC from Memory level up - A
CPU Ratio setting - 21
CPU Turbo Power Limit-E
CPU configuration
CPU Ratio Setting - 21
C1E Support - D
Hardware prefetcher - E
Adjacent Cache line prefetcher - E
Intel Virtualization tech - D
CPU TM Function - D
Execute Disabled bit - E
Intel HT Technology - D
Active Processor Cores - ALL
A20M - D
Intel Speedstep tech - D
Intel Turbo Mode tech - D
Intel C-STATE tech - D
BCLK frequency - 215
PCIE frequency - A
DRAM frequency - 1722
UCLK frequency - 3444
QPI frequency - A
Dram timing control
1st iformation - 9
2nd information - 9
3rd information - 9
EPU II phase control - 24
Load-line calibration - E
CPU differential amplitude - A
Extreme OV - E
Current voltage
Cpu voltage - 1.4125
CPU PLL voltage - 1,85
QPI-Dram voltage - 1.4
Current voltage
IOH voltage -1.2
IOH PCIE voltage - A
ICH voltage - 1.2
ICH PCIE voltage - A
Current voltage
DRAM Bus voltage -1.65
>DRAM REF voltage - A
Debug mode - STRING
Keyboard TeakIt comtrol - D
CPU spread spectrum - D
PCIE spectrum - D
CPU clock skew -A
IOH clock skew -A
What's the highest vdimm and QPI/DRAM voltages anyone has run on this board for benching?
Is Any one have the bios 0077 rampage 2 Extreme for i9 ?
http://img514.imageshack.us/img514/9317/28110712.jpg
Anyone remove qpi/dram controller?
I was going to check how good of contact the heatpipe chipset cooling assembly was getting.
I've just been laying around with the preset Level-Up features since I got the board, but I want to start with XMP now.
How do you go about with BCLK? I've toyed around with it alittle, but is it like the old front bus, where you have to go slowly forward, or do you just set it to the desired value and hope it boots?
I have noticed I can have my system totally stable, then upon reboot it would be unstable, most pronounced in memory intensive stress tests, although I had not changed any settings.
I noted all memory settings in the BIOS, then saved and exited BIOS, then re-entered after machine rebooted and rechecked all values.
To my surprise, the RTL values were now different! Amazed, I rebooted again 5 times, and each time, the RTL Values changed by themselves!
*Just as note, I have my ram set at DDR3-1600 MHz / 7-7-7-20 1T
When set to 'NORMAL' the RTL's changed as follows (RTL1/RTL2/RTL3):
Boot 1) 59/61/62
Boot 2) 59/62/63
Boot 3) 59/61/62
Boot 4) 59/62/62
Boot 5) 59/62/63
When set to 'AUTO' the RTL's changed as follows (RTL1/RTL2/RTL3):
Boot 1) 59/61/62
Boot 2) 60/62/62
Boot 3) 59/61/62
Boot 4) 59/62/64
Boot 5) 59/62/63
The Rampage II Extreme does not allow you to set a fixed value for RTL's. Instead they can be set to 'AUTO', 'NORMAL' or a delay or advance value. This obviously means that the BIOS 'chooses' the base value for either "NORMAL' or 'AUTO', and again chooses the base value which it then delays or advances when you choose to. It seems that this value changes on reboot randomly without any other settings or the ram speed being changed.
This is a major BIOS issue, as I am unable to get the RTL values to stay the same between multiple reboots. I have tried both BIOS 1406 and 1504 and both exhibit this behaviour.
I didnt check what the ASUS applied stuff was like i just stripped it and cleaned it anyway. I re-mounted it iwth OCZ Freeze and Sekisui tape.
If you havent mounted the board in your case maybe test it wired up on its box and record the temps with everest, it they look to high its a quick job to put your own TIM on.
Asus don't allow you to set a fixed value like other manufacturers do. You can only set "Auto", Normal" or "Advance X clocks" or "Delay X Clocks" - all of these options mean the board chooses the default value, and this is where the problem lies. The board chooses a different value each time you boot even though nothing else has been changed.
To clarify, the RTL's were changing every time I rebooted, when I have not changed ram speed, BCLK, timmings or anything else. Just rebooted at the exact same settings and the RTL's were different every time.
This is very bad BIOS work, we should be able to set fixed values for each RTL eg: 59/60/61 and have them not change.
I'm going to make a small upgrade soon.... on Windows 7 and OCZ Agility EX SSD drive. Well are the network drivers on the installation CD compatible with Win 7? Did anyone try to install them on a clear win 7 installation? Thx
