Nice! I hope that the one on it's way to me is of similar quality, can see why you're happy! Wish me luck :)
KRich, Awesome job!!! :up:
Vcore is great for 4400mhz. Congrats.
Yeah I always use only 4GB when OC'ing. Then add 8 and retest.
I tired Static 8 and 9, I get BSOD or some other wierd things, like reboot loop. 10 always seem to work well... I am not sure why..
Hey man that is a great result! I can't believe how low the vcore is! What is the vid on that cpu?
Good luck brother!
Davit, just lower vtt to 1.20v in bios, set ref's, then raise vtt back up. no need to load defaults.
OK. Thanks brother! Doing it right now.
Was busy getting sli to work on p-45... what do you know..
http://i195.photobucket.com/albums/z...9/DSC03491.jpg
http://i195.photobucket.com/albums/z...tmapImage3.jpg
Is everyone here using the DQ6? I have a 780i. Now that fall is coming on and cooler temps are here I am going to make some more runs at the OC.
Using asus p5q delux, I did have a Dq6, I found it to be more flakey than the asus
Holy :banana::banana::banana::banana: how'd you know my batch?! :eek:
My VID is actually 1.15v though, unless Core Temp/Real Temp are wrong.
http://ense7en.com/pics/q9650/vid1.15.JPG
In my experience, even though not perfect, CPU's are a lot flatter than heatsinks/blocks. Also as you said, a block is a lot cheaper than a Q9650. If I were you, I'd try lapping the block at least a small amount, before lapping the cpu.
Congrats on the great cpu, very nice overclock.
the best i can do with Asus RE is 480x9 :
http://i69.photobucket.com/albums/i4...Untitled-8.jpg
i cant get it to do 485fsb but im happy with the results ,still memory timing needs tweaking.
Thanks for the good luck wishes! :)
It transpires that I placed the order, finance gets agreed, then they go and sell their last 2 to someone else! I'm not going to name & shame them, but I'm a tad peeved about it! Particularly as this is coming with 8Gb of OCZ blades and a handful of modding trinkets. They have reassured me it won't be long though so I'll hopefully get it in time for the weekend.
I'm ready to receive all that extra speed :D Best of luck with 4.5 and sending all positive thoughts your way :up:
Cheers buddy :up:
All the best and looking forward to hearing your good news too :up:
Very nice. Would like to see some 3d results on that beast.
Based on your VID, it should be able to go higher than 4.1 on the right board. Same your UD3P wasn't working well for you.
Very nicely done, could you please post your BIOS template or PM me with it? Haven't really pushed my REX with the Q9650 but 4GHz was very easy, would be interesting to see your settings.
You've got a winner there, nicely done!
I can, sorta.
But life with 8 GB isn't nearly as easy as with 4 GB, & i much prefer 8 GB with a lower clock to 4 GB with higher.
I did indeed buy a UD3P for a bit, but i wasn't very happy with it. (This was with my Q9550 & Mushkin 8 GB previously, granted.)
I saw right away how nice it was for clocking w/ 4 GB, but then i put the other two DIMMs in, & it turned into crap.
I couldn't even get it to POST past 467 FSB unless i was using the 266 strap, & while i eventually i thought i got 8.5x471 stable, the exact same setting were unstable the next time i ran stesstesting (they'd passed before).
In general, i found the board to be very inconsistent & flakey for 8 GB use, so i went back to my P5Q-D, where at least i find it consistent.
Here's i'm running 4.275 GHz
http://ense7en.com/pics/q9650/Q9650%...e%202%20hr.JPG
It's not really stable though, & i don't like running settings that don't run everything i throw at it.
Also, temps get too high around 4.2 GHz or higher as somehow even my lapped TRUE sucks.
Thanks man, i will give it a shot and see what happens. Lapping kit should be here today, so we will see how it goes.
Got it brother, that is exactly what I did. Was pretty straight forward!
Thank you my friend,
No luck so far. I forgot to do my screens, but at 4.5 I am keep on failing prime,, most I got was 1.5hrs... I bumped the mch to around 1.44 and vtt to 1.36 while vcore is at 1.525... gonna play around a bit more with it. Maybe raise mch to 1.46 and vtt to 1.40...
Well vantage was weird... MY gpu score was lower when I run it on single card overclocked. I know the sli is working cuz I can turn second card off and on in nvidia control panel... but something is definitely not working.
Overclocked single gtx 295 I got P24.1K in vantage, with 2 of them only 20.5K(not oc'ed)... so I need to tinker with it a bit. Cuz I should at least break 25K
