OPP had one opty 154 at 3781Mhz :Quote:
Originally Posted by Pirated
http://www.xtremesystems.org/forums/...53#post1133453
overcrash86: thanks for the info and help...
Here is mine CABYE 0540 FPBW under water...
http://img256.imageshack.us/img256/7407/clip1be.jpg
Still testing it...but all 4 we have ordered are really hot...about 5°C more than an 148 at same speed and same voltage :rolleyes:
Regards,
Primoz
Very Nice Tatts, but Only SuperPi. Prime is the only stability test that counts.Quote:
Originally Posted by tatts
The Rest is only for Benching good.
http://img176.imageshack.us/img176/3...bujo0tt.th.jpg
silencer 64 ultra :D
This opteron is normal, for christmas a 146
Which are the best Opteron 148 steppings until now?
Updated.
http://files.upl.silentwhisper.net/u...mhzsuperpi.JPG
http://files.upl.silentwhisper.net/u...22verified.JPG
Air cooled + forgot to set fan = on when temps where lower than 35c(idle temps).
E6 :DQuote:
Originally Posted by Monge
Mhm nice one Lastviking! Which aircooler?
i'm curious if low batch number means good overclocking. Is there some kind of online database with batch numbers and OC's?
Great result Lastviking! Go Sweden :D
Hope I'll recive a CABYE 0540 next week :)
where on earth you guys getting 0540 cabye's ?
Originally Posted by SPivX
lower batch number does not guaranteed better overclock, few weeks ago I bought three 148 cabne 0528 but the one with highest batch clocked higher, required less vcore, and with MaxTcase of 67'C instead of 63'C like the rest of the lower batch.
I have never seen Opteron 148 E6 - is this new?Quote:
Originally Posted by Martin Cracauer
I meant: Which are the best Opty 148 steppings (codes) to look for?
do you believe in MaxTcase? There are Opteron's with MaxTcase 55 that do 3000+ on air / water... My two 146 CABYE 0540 FPMW with batch 0001 and 0230 will come in monday or tuesday. I'll let you know!Quote:
Originally Posted by ben805
TT Big typhoonQuote:
Originally Posted by ManagHead
thanks, i run it for 5 hours earlier and no errors so gonna try pushing it to its limits before finding a 24/7 stable clock :DQuote:
Originally Posted by Rufus7
i wouldnt bother, my 146 & 148 are exact steppings & week but the 146 is on 3.2ghz and the 148 scrapped 3ghzQuote:
nope, the batch with 0500 seems to be the best from what ive seenQuote:
yes, the 146 0540 will hit 3ghz no problem were the 144 0536 will be around 2.8ghz
http://img407.imageshack.us/img407/3...hz255633fd.jpg
:banana: :banana:
Gj :toast:Quote:
Originally Posted by GUFY
Opty 146 CABYE 0540FPAW, batch 0050. From Newegg. Using Thermaltake Big Typhoon for cooling.
http://www.3dxtreme.net/other/CPUS/O...-12hrprime.jpg
Originally Posted by Lastviking
Is that PRIME stable though?
Opteron 146, 0530 CABNE iirc, batchno. 030
IHS still on...
http://img487.imageshack.us/img487/4...5spi32m0qt.jpg
HL² gaming stable. Using 7/10 divider atm. OS untweaked XP for gaming etc.
This is really odd....I can run SP2004 for hours at 2900mhz but I cant run 1m at 2840mhz....it will error out...anyone got any ideas?
...ram maybe?
