Originally Posted by chester
??? What did I do now. I cant quite understand ya bro. :confused:
doood lied bout this ram but i pay for it not u.as fer the guy thats running 2-2-2-2chek that sisoft or whatever,ahrgh her i go shroom put here 3 smowhere i can prove it.dood as for this ram i will never buy again.if u want i can post ur newegg reply.dont do that unless ur sure please.unless iu could b wrong
... No personal attacks
Couldn't agree more, don't know where you get that attitude form. Learn to post legibly aswell.
I didnot understand you Firefoxx... which Twinmos memories will have the VXChips?
I know exactly what I posted, and it was the truth. I posted my results which were good, just because your result werent as good dont meen its my fault. It varies from person to person. If you read this hole thrad you will see that others got even better results them me. What exactly did you buy? Did you get the speed premiums or the tmII400's. Why dont you post your specs and maybe we can help you out. I would much rather have a calm Chester here then an agro Chester. But really if you do want help your coming at it the wrong way.
Originally Posted by Ubermann
I can understand where the guys coming from, just cause hes being a little rude dont meen we should be. Always try to help first, then ream em.
Sigh.Quote:
I've abused 6 different TMSP sticks.
Every single one of them did 2-2-2-x 250MHz +-2 3.3v on DFI nForce2. On current DFI nF4 Ultra-D they do more than 262MHz 2-2-2-6-7-14... 3.5V
My proc craps out before they do.
Tell me that's just plain luck.
Yup...
I know loads of ppl now using this ram, in both flavors, and some are havin' great success, while others got duds...
It is ALWAYS a crapshoot, but that's what makes it interesting...
I say Minty's review on Komplett, but I didn't go telling him off when it didn't perform, nor did I give Komplett an earache, just RMA if they're really bad, or keep running 'em til they loosen up if they have some promise...
I've got a single stick of old skool BH5 that wouldn't do anything over 220mhz and that was at cas2.5, so I ended up putting it into a friend's rig cos he doesn't clock, and in a few months I'll go 'nik 'em back and maybe they'll respond a little better...
You can't shoot the reviewer cos you got a mediocre set...it just happens...
Gray
anybody here tested new TMSP PC3500 with Bh-5 chips yet?
how is the result
thx
Yup I've got 2x512mb of the PC3500 BH-5, can get 245-250 2-2-2-5 stable but not much more. Thats with 3.53V, anymore voltage just produces errors at any setting.
My 2x512Mb SP3500 , this is memtes test5, spi 32M, blend etc stable settings.
3.6vdimm, cas 1.5-2-2-5
Hoping to burn in some more..
Nice result mate! :thumbsup:Quote:
Originally Posted by Fosco
Where'd you get 'em? Just in case there's a particular supplier that got a good batch...
Wish I'd found a set that good!
Gray
Originally Posted by Gray Mole
www.komplett.no
This is the 2 best og 4 sticks, so they vary
I cot mine from the UK Komplett...
Just luck of the draw I guess :rolleyes:
Gray
Hi all, ive been following this TwinMOS post for a while now and have decided to take the plunge, however I can get the CH-5 and BH-5 for the same price and cant decide between them, so which would you lot recommend for a 939 neo2 plat?
Have you got a DDR booster?
I'd go for the CH-5 I reckon, my BH-5 needs to many volts for decent results, the CH-5 shouldn't need as much.
im going to get a booster with my order (although not from the same place) and thanks for sugesting the CH-5 i was slightly leaning that way anyway.
oh and Minstadave i thought you were taking a break from memory forums :stick:
I still find the odd chance to sneak on Xtreme, though I can't convince my GF to give me my OcUK password back yet :slapass:Quote:
Originally Posted by AFRS
Fosco - can you show a screenshot of the bios mem settings? what fsb and multiplyer you running.
My SP3500 will do 250 @ 1.5-2-2-5 1t 3.5v at the moment, i wanna see if i can squeeze some more out
My results with TwinMOS SP PC3200 / CH-5 K0-6633 PCB:
255 MHz 1,5-2-2-4-1 or
265 MHz 2-2-2-6
are running @ 3,8 Volts. :)
Could be better. Any Tips?
cya, Bitpower
Her you go mate :)Quote:
Originally Posted by welshtom
I killed 1 stick of that exact same memory with 3.6v on it... but I must add that i ran memtest test #5 for 6 hours... I heard that generates a lot of heat lol :DQuote:
Originally Posted by BitpowerPM
I did have a fan on the mem though, just no sinks... maybe I should try that :p:
I reckon you cool your ram enough? (got any pics?) :D
Fosco you are a legend :). thanks for that, i'll have a little play around today.
The new CPUZ 1.28.6 shows cas 1.5 if you have that, i noticed you are running 1.27 so it doesnt recognise it.
As they are the best steeps of Twinmos SP 3200? :confused:
thx :rolleyes:
