guys I have 40MegaBit server in my hand + Rapidshare Primium I can help to you and your downloads only for XS if you want download any driver or BIOS or other thing from web I can Host it for you
I also am interested if there is a newer BIOS for the DS4.Quote:
Originally Posted by HamidFULL
@bingo, what resistor needs changed and to what value?
Here's the best I can do after alot of tinkering. I'm happy with it! I know some people hit higher, but for being on air and the cost of the system in general, I think its great!:cool:
I would like to personally thank everyone on these forums for all the info they post!
http://www.mts.net/~kroppa/myoc.JPG
Stability: 4 Hours+ Orthos
CPU name E6400
OC: 3400Mhz
Stepping: 6 B2
Week: L628
Code: B168
Vcore: 1.4
Load Temp. 57C
Cooling: Air
Cooler brand/model: Arctic Cooling Freezer 7 Pro
Motherboard: Gigabyte GA-965P-DS3 Revision C2
Bios Version: F7
RAM brand: Team Xtreem 2x1GB
RAM rated speed: 6400
RAM actual speed: 850
Latency: 4-4-4-10
My mistake :)Quote:
Originally Posted by newls1
We are waiting on Gigabyte to approve publication of the change. I have a meeting with them tonight.Quote:
Originally Posted by cirthix
ill pray that you'll get the approval. =P
regards
Tanx Bingo when we can see new BIOS for DS4?Quote:
Originally Posted by bingo13
Gigabyte engineering believes with the final F8 BIOS that the resistor change will not be needed now, although it certainly helps. Once we have another release I will get it posted up quickly. It appears the current interm build is reaching 520~525 without the resistor now.Quote:
Originally Posted by ferds
I have F7E, will see if we can get it approved for general beta release, if not then a final release is scheduled shortly. I cannot provide it without Gigabyte's permission.Quote:
Any clue when that final bios is coming, next week this week?
So I just read the last few posts and it sounds like with a new bios the DS series will be able to break the D9 curse? Is this correct or should I read back a few posts? I'm tired of being stuck in the middle 470's..
This is excellent news for all DS users! Any news on the DQ6?Quote:
Thanks Bingo, I really appreciate the info you bring us!!!!
bingo, your info really enlights us...thanks alot...
Bingo - thanks for updates!
:banana: :banana: :banana:Quote:
:woot:
Bingo any news on the raid bios is going to be updated? Boot up(detecting hard drives etc) seems to take me quite a while, i dont know if this is a general raid issue or an issue with the board or the bios. Thanks for keeping us up to date anyway.
Can you please list the drives you are using and which board? I do not have any issues with the Seagate 7200.10 series but have not tried the Raptors or Hitachi drives yet. The JMicron controller firmware is one step down currently and we have asked Gigabyte to update it on all three boards.Quote:
Originally Posted by FirePhoenixCtk
I think it has something to do with having RAID configured but no actual RAID arrays...
Here's what I believe is the best that I'll get using the F8i BIOS.
Attachment 53177
Using these settings Orthos passed 12hrs.
CPU Clock Ratio:.................... 8x
CPU Host Clock Control:.......... Enabled
CPU Host Frequency (Mhz):..... 406
PCI Express Frequency (Mhz):. Auto
System Memory Multiplier:...... 2.00
Memory Frequency (Mhz):....... 812
DRAM Timing Selectable:........ Manual
CAS Latency Time:................. 5
DRAM RAS# to CAS# Delay:... 5
DRAM RAS# Precharge:.......... 5
Precharge delay (rRAS):......... 18
System Voltage Control:......... Manual
DIMM OverVoltage Control:..... +0.4V
PCI-E OverVoltage Control:..... Normal
(G)MCH OverVoltage Control:.. +0.2V
FSB OverVoltage Control:....... +0.2V
CPU Voltage Control:.............. 1.4750
When I tried 420x8 Orthos failed. I couldn't Boot with any FSB above 420. My previous 406x8 using 4-4-4-12 passed orthos for 30 min but failed at 46 min. When I raised the timing to 5-5-5-18 Orthos was still running after 12 hours.
I believe that I have a memory problem. I tried 266x8 3.00 (ddr 800) and this booted with orthos for 30 min. I tried 266x8 3.33 (ddr 885), 256x8 3.33 (ddr 852) and they wouldn't boot. I then tried 280x8 3.00 (ddr 840) and 420x8 2.00 (ddr 840) and they booted.
Waiting for the next BIOS.
I hearby apologize for my mistreatment of Bingo. I was wrong in my assumptions about him and want everyone to know he is the real deal. I should not have lept to conclusions and I very sorry.
Please keep the I told you so's to a minimum. Thankyou!
Hey well done your a real man, good on you.:)Quote:
Originally Posted by JPH1589
What the hell is this HPET Support thingy seen in beta F8i for the DS3?
There is a new beta for the DQ6. I do not think it is ready for public release yet but if it comes close after testing this week then we will try and get it released. We are trying to get any public betas in a "good enough" state so that it will not cripple your system. ;)Quote:
Originally Posted by eXceededgoku
Gigabyte is hoping to get the DS3 F8 finalized next week and the DS4 F7 shortly afterwards. There are some code changes in the DQ6 BIOS so I do not have a date yet. I hope everyone appreciates the fact that Gigabyte is really taking your comments seriously and they are doing their best to address issues. I can tell you from my experiences with them at this time they are burning the midnight oil on quickly solving any potential issues that arise.
New Marvell Yukon drivers for S3/DS3/DS4/DQ6 (2000/XP/x86 + x64):
http://www.marvell.com/drivers/uploa...x86_v86123.zip
Vista x86 drivers:
http://www.marvell.com/drivers/uploa..._V9.12.3.3.zip
CPU-Z 1.37.1:
http://bakkap.free.fr/Softs/cpu-z-137-1.zip
Realtek HD audio drivers for all GB boards, version 1.51:
http://www.realtek.com.tw/downloads/...&GetDown=false
