Originally Posted by
fungry
Haha I think I already spend too much money. It is already sad enough that I can't make use of my other TR HR05s.... because the screw that goes through the hole for the southbridge will impede the installation of the gpu. ZZZZZZZ
the setup may change in a day or two because i don't like how the SATA cables are stretched from the very bottom to the very top of the case.
As for my temperatures. When I mount the fan on the HR05 for the northbridge, it drops from 46 degrees to 39 degrees (active cooling). The CPU idles at 30 degrees (with overclock settings) and the load temperature is around 53 degrees. At stock settings (1.86ghz etc), the cpu idles at 23 degrees.
