Originally Posted by
Simps
I totally agree that for benching, the Maximus II Formula will not be the best choice, and I never said that. We know Biostar P45 is a better bencher, DFI p45 DK is more efficient on superpi, and as you said, those Gigabyte UD3P are showing some nice FSB clocks and mem clocks for benching too. And there are other examples out there.
But as I said before, I am talking about 24/7. About the memory issue, YES, it is true, but, as an example, for a screenshot a 12000mb/s is very different from a 10000mb/s on everest. But on a day to day performance on games or other applications, it means absolutely nothing. Other things are much more important as stability, and low volts for higher solid stable clocks, and more important, SAFFER volts for 24/7 use for years.
Maximus II Formula can keep overclocks, with lower volts then all other boards (I am saying this, because I visit the other board threads, and I can compare), including your UD3P. MIIF 16 phase power do make a difference on vcore and vFSB against the 6 power design of the UD3P, and the 8 - 12 power design of other boards. Mosfets on MIIF will ALWAYS be cooler then on those other boards, and more stable at very high quad clocks. Maybe it has some problems clocking ram at some point, but that is far beyond a 24/7 use situation anyway.
I will quote Leeghoofd on this:
[]'s
Simps
