Originally Posted by
Simps
Look, what we are doing here, is what everybody seem to be doing with this board. We are randomly changing values, trying to "magically" find the right one. This is not the way to work with this board. That is why I wrote that guide. But to follow it, you will have to start from zero, and fine tune everything again. It is hard work, but that is the way to find the sweet spot.
But anyway, stop changing the settings like crazy, or you will never find what is holding you back.
Keep your current bios setting, and now only work on the RAM, to find if the problems is there.
It looks like, it is probably your ram that can't handle DDR2-1200 PL8 at 2.1v, on your FSB.
You need to know this for sure. Do one of the following without changing your settings:
1) Raise your Vdimm to 2.2 and test again.
2) If you don't wanna raise Vdimm, then just downgrade your ram from DDR2-1200+ to DDR2-1000 or something like that, keeping all the other settings as it is, and test again.
If you get no more BSOD, then the problem was your RAM needing more volts for sure.
Report results.
[]'s
Simps
