Trans Booster only works with the 333 and 400 settings for me. Any others and I get DET DRAM hang. I also run my NB voltage higher. 1.67v or so with water cooling.
Edited my post. I left out 2 very important words: "for me".
My bad.
Keep in mind I am running 4x1GB sticks of 1066 (OCZ and Crucial) at 5-5-5-15 with Perf. lvl. set to 7. I am rather impressed overall.
I just checked CPU-Z and my memory settings look strange...why do JDEC #1, JDEC #2 and EPP #1 all have different timings and voltages?...shouldn't they all be the same/matching?...or is that normal?
also in the 2nd screenshot is the FSB.DRAM supposed to be running at 5:6?
http://img5.uploadhouse.com/fileuplo...c30eac2983.jpg http://img2.uploadhouse.com/fileuplo...c044461206.jpg
most people are posting settings for memory @ pc8500;
i wish i could attain those levels but im using pc6400.
who has good settings for ballistix 6400 ?
Flashed back to 0214 and now i finally can boot at 450x9,5 again. Found a solution also for my auto vcore, reset bios to default and change vcore from auto to like 1.125 and rebooted. Now i can boot with any vcore i will. Simple problem but hard to find sometimes :)
Running at PL7 right now ......
Has ne1 bothered with the comparison that Zucker2k was asking for yet?
If not I will try it after a fresh beverage
i could probably swap in some ocz 6400's from my gf's computer to test and have a go at those settings...
Flashed 0219 from 1004
http://img187.imageshack.us/img187/6...ablepq7.th.jpg
E6750 - CRUCIAL BALLISTAX 8500
I have a set of patriot 9600's that I will try out next, they were quite stable with the formula bios.
so what is my actual memory voltage, 2.1v or 1.8v?...in PC Probe my DRAM voltage shows as 1.98v but CPU-Z shows 2 other voltages
25mhz more on the fsb and the mobo is skyrocketed....
i wish i had an 8500 to test higher...
grab me a few? :ROTF:
here are my updated numbers...making good progress here.
http://img186.imageshack.us/img186/2...mem3rp0.th.png
thanks for your time
man, I can't believe. I've got 3.4ghz! in 10 seconds!
I was thinking that was needed to set all that strange parameters to get anything, like all of you listed in yours settings.
But so I "pretended" it was an ABIT, and made simple:
set FSB to 378x9
FSB STrap 400mhz
Vcore 1.375
all the rest on AUTO!
my BIOS is 505
just it! It's holding fine! got 5150 CPU score on 3dmark06,
and the temps are below 35ºC Idle
just can't raise the memos, but it was a nice start!
Does anyone know what the curing time is for a "fresh application" of artic silver 5
By curing time, i mean when does artic silver show its benefits
Kevin
@ giorgos th. , whats your max fsb you've managed to attain with your processor?
i cant get anything semi stable over 430 and 440 is so unstable its not funny and thats with 266 strap and its just raping my ram for MHz, no other straps will work over 430ish for me :confused:
this pic was with MF Bios, but have flashed to RF 219 nw, but still nothing very stable over 430. anybody got any ideas, i thought 450fsbQC was supposed to be a piece of cake with this board!!?
http://img301.imageshack.us/img301/7337/43478128eh0.jpg
i believe its 60 to 70 hours of computer usage time
