Normal.
I've got a Crucial C300 SATA III SSD connected to the Marvel SATA _6G_1 connectors on the motherboard however I do not see anything in the CMOS settings that is referencing the drive or indicating that it sees the drive. What I'm I suppose to see in the CMOS settings the indicates the the BIOS sees the drive that is connected to it?. Is there anything that is supposed to be indicated in the CMOS settings that indicates that the drive is configured properly. I am going to use the drive as the boot drive but as with a SATA hard drive I need to know that the BIOS configures the drive properly. Please respond to this post with the information as to how do I install and configure this drive.
Looks and "feels" same to me. :rolleyes:
I wouldn't go over 1.25V IOH, as it's usually not needed for 24/7. I took it to 1.4V on air for finding max BCLK. I use 1.15V for 24/7 just to be safe when gaming, but it can run 205 BCLK @ default 1.1V
AFAIK, CPU Differential Amplitude and CPU PWM Frequency could give you that extra stability when on the edge.
CPU and IOH Clock Skew is used for high overclock under extreme cold.
Someone correct me if I'm wrong.
Cool...I have the same SSD 256GB. I had issues getting the mobo to detect the SSD. I only left the SSD connected and optical drives and booted with BIOS defaults. SSD is connected to intel on-board and not the sata3 controller...better performance (dont have spare PCI-e for addin card). Also make sure that ur HDD priorities is in check for optical and HDDs (SSD should be top. For example my HDDs list 1. SSD 2. 1TB 3. 1TB...etc.
Quick question - Will running the PLL voltage lower than normal (around 1.4) cause any degradation of my i7 970?
I dont have an ssd, but i have a 1tb sata_6g wd black edition.
connected it to the marvel controller.
in the bios where it configs onboard devices, change onboard sata6g controller to ahci mode.
U should be able to see it and the speed when marvell bios is posting or enter the marvel raid utility to verify that it sees it and using the right speed.
but even without setting it to ahci, it should still run at a reduced speed
you shouldnt have to set anything for sata drives to work.
good luck
my 980x is 100% stable: 32x133 at 1.375v
id say its safe for 24/7 on the stock cooler
but i down clock/volt it when im not playing games to save elec
I'm concerned that I have damaged either my CPU, DRAM, or motherboard component.
I'm using a full watercooling loop; but had been pushing voltages a little. For some passes of LinX @ 4.3 - 4.4Ghz, I had my CPU vcore at 1.5 with an i7 930. I also ran a high overclock with close to 1.5 vcore 24/7 ... for a couple of weeks.
I'd also experimented with memory speeds / relative CPU overclock, and had set the XMP profile that loaded from my G-Skill Trident 3 x 2GB sticks. The XMP profile seemed to have inordinately high VTT/QPI - about 1.48v ... I should have known better.
Anyway - suffice to say that I may have been brash with my voltages, even though most of my temps seemed within limits and a fair way off TJ max.
Lately, I've had to tune back my overclock on my i7 930 to sub 4Ghz ... and I'm still getting strange instabilities. I can still LinX pass @ 4Ghz, but I'm getting system freeze in my gaming applications at that overclock. I've eliminated my GPU's and PSU from any potential problem ... and right now I'm testing the system running just two of my three RAM sticks. LinX is now stable happily at 4.2 Ghz again, but with 4GB or RAM (dual channel).
I'm really only a newbie; but my thoughts are that I have degraded my memory controller on the i7 930. I can't hold clocks as high, and overclocks that were stable are now impossible to hold. Is my assumption consistent with what I'm experiencing?
I did for a time run my DRAM voltage at 1.72v; but I think this is more acceptable than running my QPI at about 1.48v ... and CPU at close to 1.5.
It's not the end of the world, if I've degraded the i7 930 to the point of uselessness, it's not a big deal to replace it since it's a relatively cheap CPU. Same with the DRAM; if that's the problem. The REAL frustration is that I'm not sure where the problem lies ... perhaps I have caused some fault in the actual RIIIE motherboard? This last possibility is the one I fear the the most, it's an expensive component, and I've set it all up with the water loop - I don't want to have to do a full system build again with a new motherboard, at least not right now.
Just to reiterate, I'm getting system freezes (not BSOD) when trying to game using overclocks that were once stable. The RIIIE has proven a great overclocking board, but I may have overvolted a bit too much, stupidly. Do any of you more experienced users think that my assumption of CPU degradation, in particular the memory controller (which I think is on the CPU) is correct?
I would say it is the CPU. It is pretty hard to damage a mobo without doing it physically or running it overheated for long periods of time.
I am guessing you dont have another proc to test with? Easy way would be to find another one to test with and start to narrow down the culprit. Test with a new proc first, then if still the prob, test memory. If no go then it gets more interesting. You would then have to look into mobo, psu and so on down the line.
I havent scrapped a i7 proc yet but I did really screw a Q6600 and it exhibited extremely strange behavior close to what you describe. Zsamz has it in a family members rig running sub 2Ghz to run stable, and it was all done with a high clock, multi hours Prime run.
I hope you get it sorted :)
I don't know, I run mine @ 1.2V :D Ask me in a couple of months. ;)
I actually had different experience and only know that bassplayer had found it to be more stable with Bloomfield.
But if it works... :up:
@Toritechie:
I could not agree more with turtletrax, but there is one thing you can do first, just to be sure, and doesn't require additional HW. Take that 3rd memory stick you pulled out and swap with 2nd one that is still on MB. That way you will be sure there is no problem with one of RAM sticks and that third channel on CPU's IMC is dammaged.
I've just finished a long gaming session with no freezes; using my old overclock of 4.2Ghz; but just using dual channel 4GB RAM. System was rock solid, I also did a LinX pass on it without a hitch. Could I be lucky enough that the RAM stick I pulled out was a bad one? I did a windows memcheck (from the F8 menu as you boot), and it said my memory was fine ....
Perhaps there is a reduced stress on my possibly damaged i7 930, I would imagine it'd be easier for the memory controller to manage 2 channels rather than 3 ...
hmm "a linx pass"? Define stability?
For me, i run IBT first for 5 runs max setting. Its fast to identify whether system is more or less stable. Then reboot and run linx 75/100x for 4/6/8 hours overnight while i zzzz. 8)
If you suspect memory, run memtest overnight?
Had used Trident b4 this set, don;t remember it need 1.72 unless you are squeezing it to like 7-7-7-21-1T kind of timing.
hows 0011 for bloomfield? :) looking to play 920 d0 on ln2 for a couple days
Peoples...my CPU PLL Voltage setting is high. This is set to 1.8v at the moment, from previous responses it should be lower. Can someone give me what the default should be (1.1v or 1.25v?) and what should be my max with a 980x please? Thank u very much:-)
Is it just me or is Turbo mode unstable for a 930 @ 4.2? I now have it stable at 4.2 200x21 (1.325v) 2000 RAM 7-9-7-24 but would like to push for 4.5. After experimenting for HOURS I discovered the following:
1. Anything over 4.2 (x21) needs ALL C-Stepping options OFF to even boot which adds an extra 3 degrees onto the max temp
2. Anything over 4.4 needs a LOT more juice. Even 1.41v couldn't bench without BSOD'ing..
3. Anything over 4.4 runs a LOT hotter. I'm talking 90+ under 100% load compared to 76 @ 4.2Ghz. Is 90+ dangerous?
4. It HATES 22x. 21x it is.
5. Turbo mode decreases RAM latency from 40.8 to 40.0 with CL7 timings in Everest
6. Holy :banana::banana::banana::banana: overclocking can consume your life... :-/
So I bumped up to 4.3 (205x21) and 2050 RAM with slightly higher RAM timings and a small compromise in temp. Seems stable but haven't run intensive tests yet. Superpi 1M is 9.5sec if I remember correctly. Quick bios rundown for current 24/7 setup:
CPU Freq: 4.2
DRAM: 2005
Bclock: 200
PCIE: 100 (+?) 8800GT OC
Multi: 21
Cpu vcore: 1.325
QPI: 1.5ish AUTO (1.4 or lower won't boot)
PLL: 1.810 (although it runs stable @ 1.65 I heard 1.8+ for Bloomfield, right?)
DRAM: 1.65 (Recommended by Kingston for 2000Mhz)
Sorry about the lack of detail. It's 1:22am and I should be sleeping. Should I persist with a 22x or 23x multi, or stick with the 21x and push the bclock? I'm still not too sure of the impact QPI and PLL voltages make to stability. If anyone could shed any light on this it would be much appreciated! :)
Thank you and goodnight
x
run memory 1600-1800mhz @ 6-8-6-4-60 needs less vtt ;)+ less stress +its just as fast:yepp:
push the cpu till it caves in lol intel will give you a new one:D
or you can give her to a freind n get a good 920 or a 950
my mom still running the q6600 that turtletrax tortured :rofl:
So am I right in understanding:
1. Default in BIOS is correct at 1.8v
2. People have run this as low as 1.2 (dom being one of the people who do...er...hello Dom^_^)
Can someone tell me the advantage of using less voltage in this case? Lack of voltage can also kill hardware and kind of weary of messing the hardware due to my lack of knowledge:confused:
