Im getting the LT version of this board, just wondering if anyone is watercooling the northbridge and if so, with what waterblock.
nzbleach,
I've been interested in watercooling NB but I havn't found a suitable block yet (although I think there are a couple that would fit although their not meant for this board or chipset)? To be honest though I'm having pretty good results from using a small adjustable fan directed at NB area, pretty decent stock blocks and heatpipe arrangement (at least at my current setttings the stock cooling is working fine).
By the way guys my new replacment eVGA 8800GTX is working at 100%, something must have happened to my original card from the time I removed from eVGA 680i and installed into the DFI? I'm glad to now know it's not any kind of incompatibility between the card and motherboard!
You know water cooling the North bridge is completely unnecessary :)
ok i just flashed the 12/05 beta... didn't see any difference (maybe since the 12/05 was intended for Yorkies/Wolfies...??)...
noticed too that the O.C Retry didn't seem to work for me...i set it to 1 & i tried to do an OC fail, but i still got the C1 error, so i had to clear CMOS.
& i seem to be unable to set my RAM's fine clock settings, i tried to change it to More Aggressive but i get an OC fail...& when i tried flashing back to previous bios, i can't set the fine clock settings anymore. but it works if i keep it at AUTO. hmmm could my GKX finally taken it's toll on me?:confused:
@ Brother Esau
how much do you sell the pre flashed bios chip?
do you accept payment thru western union?
how much is shipping cost to manila philippines & how long is the shipping time frame?
thanks in advance :)
I would be glad to help you out I kindly take donations of any sort:D
you got pm brotha esau:)
Nope. NB voltage only 1.61 from bios option.
Here's the screenshoot with bios 1107 all default, pcie link width show the correct value (16x):
http://i135.photobucket.com/albums/q...AllDefault.png
And this is screenshoot with newest beta bios, 1205, suddenly pcie link width show the weird (1x):
http://i135.photobucket.com/albums/q...a_98/error.png
I flashed with the newest bios to fix the weirdness, but unfortunately, that problem isn't from mobo bios problem.
My rig's specs:
Vista x64 & XP (dual boot)
WDC 2x750Gb Sata2 AAKS
Ballistix PC8500
Q6600
nv 8800GT
DTek Fuzion+TC PA 120.3
Corsair HX620
Sorry for my bad English, bro.
Do any of you guys trid this new BIOS: 2007/12/24? and is any good over the 2007/12/05?
oh another is out? hmmm....
Date Code: 2007/12/24
File: LP35DC24.ZIP
Major Reasons of Change:
1. Change ICH9R AHCI ROM.
2. Pach for QX9650 radio issue .
3. Adjust dram tfine item value .
4. Add O.C fail item.
http://www.dfi.com.tw/Support/Downlo...FLAG=B&SITE=US
More dram tuning?:D
Can anybody compare new bios with the 9/13 in latency and read rate. My wc pump died so I'm unable to, but I doubt it will be any faster.
you got pm brotha esau :D
tnx
Hello !
I'm a french user, so excuse my bad english ^^
I would like to know if anybody here know's how to activate 16x/16x 2nd pci-e slot...
I heard rumors about it, and after vain searchs, i didn't got another solution than to post it here...
Thank you in advance :jap:
MCW30 sits just fine on the northbridge, I have one myself on it. I did not try the SB, but from what was said earlier in this thread, it won't be a good fit. DD Maze 4 however, will fit the SB (atleast from what someone said earlier in this thread).
you got another pm brotha esau :D
tnx
Any problem with GKX microns on this mobo anyone?
I flashed the new 12/24 bios earlier today. So far it is identical to the 12/05 bios except for the fact that the Special JMB386 patch option is no longer listed in the 12/24 where it is in the 12/05 bios. OC Fail Retry option is still present and should be a nice feature as long as it works.
using some Team Group GKXs... no problems noted... except that i can't do Fine Clock Delay Settings in the bios (i don't know why... :confused: )
http://i116.photobucket.com/albums/o...Hz2GB-Pr-1.jpg
http://valid.x86-secret.com/show_oc.php?id=280084
http://i116.photobucket.com/albums/o...em575Mhz02.jpg
http://valid.x86-secret.com/show_oc.php?id=287634
