just got these for 100Euro less than normal......nice nice for OCZ DDR2 PC2-6400 Platinum Enhanced Bandwidth 2.1V D9DQT / Micron BT-3 2*1GB
Does any of you have TwinMos Twister DDR800 sticks? Any results when it comes to OC? They are relabeled, so I can't find out which chips they are based on. I'll be able to check their potential when I get my mobo, but for now I'm just curious about their OC.
any pics of the chips mach?
the same type as in #226. It may be anything. Ms sticks were the chaepest DDR800 2x1GB CL5 I could buy in Poland, so I assume they are based on the Elpida chips, but they might be micron D9 as well. I can't check it out, as I will have my mobo - Gigabyte DQ6 - on Friday. I'm just curious.Quote:
Originally Posted by fakhrain
any idea with these? Aeneon or Micron?
http://img87.imageshack.us/img87/1580/img0528mc4.th.jpg http://img147.imageshack.us/img147/2...stongv1.th.jpg http://img147.imageshack.us/img147/4...0534wy2.th.jpg
I think the Corsair with the dark colour PCB could be Micron... it's slightly rectangular, the brown dot, and there are 4 faded letters on the top left.
Sometime for Update Post #1
what chip should have this http://www.ocztechnology.com/product...num_revision_2
OCZ EL DDR2 PC2-6400 / 800 MHz / Enhanced Latency / Platinum XTC Edition / Revision 2
:confused:
well that ram i bought is not really good i've swapped with this now
OCZ DDR2 PC7200-443 Platinum XTC 2x1GB Kit 2.1v (D9GKX)
check the chips and they're real :)
D9GKX ???
this chips are on my Gskill 1000 HZ
they goes realy good
here's a photo(from an online review but same chip of mine)
http://www.overclockersonline.com/im...ge/specs-3.jpg
i have theese TEAM EXTREEM DDR2 PC2-6400 CL-4.4.4 10@800mhz 2X1024 , D9GMH chip 2,0-2,2v HS-SILVER ALU.
not tested yet but will do when my X6800 arrive
http://img525.imageshack.us/img525/2...packmt9.th.jpg
http://img504.imageshack.us/img504/5...nihsml9.th.jpg
http://img504.imageshack.us/img504/3...ipenuu9.th.jpg
Can someone please tell me what chips have the Team group value line?
TEAM XTREEM DDR2 256/512/1024/ PC2-5300 ???V 667@5-5-5-12 HS= Without
If that's selectra they use some value stuff. Chips look exactly like DDR1 chips.
Please mates I have this memory for good price http://geilusa.com/proddetail.asp?linenumber=71 ,can eny one thell me is this ram good for oc,and what I can expect of them?
anybody knows what chips does Corsair 5400C4 v5.7 and v8.1 use?
The tricky thing is that Micron don't generally sell blank easily brandable chips. Even ballistix have the D9GKX/D9DQT visible under the Ballistix printing on the IC's.Quote:
Very possible though with the 4 letters and location of the dot on the IC.
I found a review that shows this SuperTalent uses D9GCT.Quote:
Originally Posted by GoriLLakoS
http://www.overclockersonline.com/in...num=396&pnum=2
something about MDT ddr2 kits??
2048MB G.SKILL PC2-667 CL3 KIT F2-5400CL3D-2GBGA
What chips are on these new sticks????
1)Now that the Fatbodies are no longer produced which is the best D9XXX chip?
2)Between D9GMH and D9GKX which seems to perform better?
As you said the D9GMH and D9GKX are the best. Chips do clock good, I think D9GKX is a little bit better at high Mhz, I think they are same die only other speedbind just as BH-5 / BH-6 :)Quote:
Originally Posted by gregorisvas
Hmmm...Indeed..D9GKX=400MHz,D9GMH=333MHz..(accordi ng to Micron :p )
Did someone has buffalo ?
I'm kind of running on a low budget since the E6600 and the ds4 got all my money:p:
I have a 2GB kit of PQI Turbo DDR2 5400 (4-4-4-12) will run at 397 @ 1.8 volts I am trying to figure out what chips are on the sticks. I pulled a heat spreader but the pictures are not real clear.
The Markings on the chip are TAP757-C93G there is a tan dot right next to the marking. Looking at the chips from the connector edge the dot is in the lower right hand corner.
Thanks in advance for any help
GEIL DDR2 ULTRA 512/1024/2X512/2X1024-6400 800@4-4-4-121.8-2.3V chips??HS=Orange
These are the chips on my 2GB pair...
http://www.motormice.com/_images/geil6400chipcodes.JPG
