Got that program to... Aint realy 100% just try 5*100 mhz Thoroughbred, 200+? I think it becomes a bit optimistic to with higher speeds.
But the closest you can get to 200*13 cpu when getting a barton cpu is the 3200+ right?
(3200/2200)*2600=3782 That gets you as close to the pr rating one could calculate, if AMD was to change the rating due to the high clockspeed no one knows, probably will not be any barton with 2600mhz stock.
Pretty easy example when using 200fsb, but otherwise its way worse.
