Good idea, hmm I already have MW2 installed and AvP so I should also check how it feels compared to my c2d system.
anyone else get automatic freeze if over 4.0QPI speed.
250bclk/115pci-e 1.4vtt 1.4vcore.
249 is a rock, then 250 craps the bed everytime QPI goes over 4ghz exactly. :shrug: cant say im dissapointed in 250bclk on a hex :ROTF:
http://valid.canardpc.com/show_oc.php?id=1189325
We didn't say it was unstable. We said it was less stable compared to lower switching frequency. Of course bumping the voltage up a little will stabilise overclocks using 1000khz that would have been stable using a lower switching frequency.
For me, as has been mirrored by a few others, found that with a fixed VCore that is on the brink of stability at a given CPU speed, the higher the PWM switching frequency set the quicker LinX fails.
How much faster were you guys able to run with PWM set at 1000khz compared to 250khz? And with which BIOS version?
don't own a R3E but Gary/bingo13 outlined how to raid the 2x sata3 6g ports http://i4memory.com/f54/asus-rampage...14/#post130391
RAID is supported on the Marvell 9128 SATA 6G chipset. In order to access the Marvell RAID configuration utility for SATA6G you must first enter the BIOS and set the SATA 6G option to 'AHCI'. Then you can save and exit the BIOS and during POST upon the reboot process press Ctrl+M to enter the Marvell RAID configuration utility.
cheers 4 the heads up George, Ill go check that out.
BTW If anyone is interested there is a faulty RE2 on E-Bay 48 minutes left current bid £48, maybe fixable maybe 4 spares !!
http://cgi.ebay.co.uk/ASUS-Rampage-I...item4aa10e6ef6
Rick
Better pix of the EK full board block now up .... this is the slightly more expensive acetal nickel one ( the one im waiting for )
I think this is gonna look great
Where can I find the option to enable Dynamic vcore?
This option is described in the manual as the "CPU Voltage Control [Absolute (VID)]".
bios: 601
Memory g.skill trident 2000 cl9 does not work properly on this board.
xmp profile gives bsod :(
240 bclk with 980x and cpuz says my board is a rev 2. xx. Rev 2 already??
@Splave what version is your board?
same :up:
That might explain things, thanks for the info Splave.
Board Good with ram too :D
Splave , Your 980x looks sweat . Very nice !
Very nice results Splave :shocked:
What ram you're using?
https://shop.corsair.com/store/item_...spx?id=1235506
embarassed yes ;)
They were $200 a stick now $250 :o
Anyone know what size fan is on the NB optional heatsink?
