I love this LiLi inspired case. Gimme!
oh wow, it just keeps getting better.
assuming they'll be black sata connectors? are they right angle at both ends? i'm hoping not as most mobos i would imagine would have conflicts with that as is the case with mine.
the power adapter adapts a standard 4 pin molex connector i'd guess?
i'm a man of details, what can i say? from the sounds and looks of it so are the people at corsair. this case packs more features and added little details than any case i've ever seen.
Right angle on one end, straight on the other. All connectors are black.
The power adapter is 1-SATA male to 4-SATA female to connect a single SATA power connector to all 4 drive ports. Here's some images to give you guys some scale of the case and how it all hooks up.
http://i40.tinypic.com/t9ijxd.jpg
http://i42.tinypic.com/2076as2.jpg
http://i41.tinypic.com/8vw2a0.jpg
looks good.
very very nice, i won't have to buy my own black sata connectors now.
seems like you guys considered just about everything.
Can the lower harddrive case be removed to fit another radiator.
that is a HUGE case. but a certain must have :D
Il be buying one of these
Excellent, just gets better and better, just love the mat black finish!
And no PSU included either, perfect! ;)
How is the ETA in Europe, Norway to be more precise? :D
can we get a pic of the front i/o panel?
redbeard, my hat is off to you. that is a stellar case, i'm lovin' the cable management and tripple rad installation.
im not a fan of the curved window looks a bit goofy to me, but id have to see it with everything mounted to tell.
Apologies if this is a dumb question, but I am not too familiar with SATA hot swap. Does this system play well with RAID configurations?
That case is gigantic! Look at all the rad space.
well done RedBeard
I hope to have one asap
Sweet cant wait for early july to come.
Anyone know how thick a rad can be fitted in it without getting in the way of the mobo?
Ryan over at PCPer has a video posted and some more info
http://www.pcper.com/comments.php?nid=7255
edit: darn, no [yt][/yt]?
cheers nice video i was looking for it
but now i have a doubt
that was the retail rls of 800D?
i was looking at the back of the "socket/screw hole" and it didn't match all the 4 screws so it makes it useless since i can't remove screw/backplate of my waterblock or whatsoever :shakes:
i hope it's not the final one
yeah i was wondering about that backplate, and if there really is enough room to get in there.
http://www.pcper.com/images/news/corsaircase/09.jpg
how much testing was done with that feature? is there an estimate for what % of the motherboards will work with it?
if you watch the video he states that it's an earlier build of the case and that they are or have reworked the back plate positioning for the final build of the case. he also says that there's some more retooling to be done before it's released to market.
redbeard may want to confirm any of this though.
