Jethro, may I suggest if really you want to stay with AMD now, look at buying either a Windsor X2 6400+ (@$180 for stock speeds) or a Brisbane X2 5000+ (@$130 for OCing). Both would be faster in common desktop programs and games than the higher priced aned lower clocked Phenom units. You can use the CPU with an AM2+ board (when available) and upgrade to Phenom when AMD gets higher clocks out of them. Remember, the next generation of Phenom processors (when they switch to 45nm manufacturing) will use DDR3 memory and will equire a new motherboard see link http://www.dailytech.com/AMD+45nm+DD...rticle7132.htm . Buying Phenom now (except for experimenting as JumpingJack noted) just doesn't make any sense at this time, as there are faster (per Tom's hardware review http://www.tomshardware.com/2007/11/...eb/page21.html) and lower priced options for even AMD itself. Just an idea.
