Why do you think that there is a 20% improvement from 32bit to 64bit?
correct, this (NB FID) can not be changed on the fly (the register can be adjusted but NB clock doesnt actually change). a BIOS item will allow NB multiplier (NB FID) adjustment.Quote:
Almost same time...difference is within fluctuation, I think.
NB@1.6G may be enough for single thread program with dual DDR2-667 access!?
or I suspect my NB multiplier changing method is incomplete
Thanks to all guys, and kyosen. :)
Kysoen: Are you sure there is almost no difference with different DDR2 clocks in CB10? It should be around 100 CB between 667 and 800.
Hope you don't mind me quoting one of your tests Kyson, but I just happend to spot an almost identical 3dmark run on OCAU with a Q6600 @ 2.4:
8800GT+ Q6600@ 2.4 : http://imagestore.ugbox.net/aview/3D...3db6c787b03544
11174 3dmarks
SM2:4651
SM3:4764
CPU: 3473
8800GT+ 2350@ 2.4: http://www.oohashi.jp/c-board/file/3..._HTx4_88GT.png
10926 3dmarks
SM2:4439
SM3:4672
CPU: 3553
that's a nice one by 2350 :up:
looks like Opty is going to be a good one..:)
That's because(the higher intel score) the intel system was benched on Vista while AMD was on win 2003.The driver was obviously better on Vista(2003 is kinda old) and don't forget the HT speed the Barcelona was running with, along with regged mem. with cas 5.
The important thing here is that K10 scored better in CPU score dept.
oops, Cheers Savantu. :)
I had all the intel SM scores in the wrong spot before first ninja edit too :/ I'm a bit tired (exuses)
Well , what's obviously for you isn't for others.
The 2003 driver is basically the XP one.I'm pretty sure the XP driver is better than the new Vista ones.They had 6 years to perfect it after all.
Secondly , HT speed won't improve scores.
Thirdly , we don't know the RAM settings for the Intel system.Kyosen said : * DDR2-667 or 800 makes almost no difference.
I'm pretty sure that will also happen on desktops.The large latency of the L3 pretty much negates the few ns won or lost by using 667/800/1066RAM plus you have better prefetchers , in other words K10 will be less sensitive to memory latency than K8.
True.Quote:
Did it use 1 or 2 CPUs ? It is a DP board anyway.
More importantly , this post pretty much makes all the above useless :
http://www.xtremesystems.org/forums/...&postcount=181
BA is B1 for mass production , the differences are none => BA=B1 in performance.Quote:
CPU clock: 3DMark Score / CPU Score
K10(BA) 2.0G=222x9: 9482 / 2999
K10(B1) 2.0G=200x10: 9353 / 2979
K10(B1) 2.2G=220x10: 10148 / 3267
K10(B1) 2.4G=240x10: 10796 / 3560
K10(B1, 3core) 2.4G=240x10: 10420 / 2830
K10(B1, 2core) 2.4G=240x10; 9423 / 1888
Kentsfield 2.4G=267x9: 11901 / 3845
Kentsfield 3.0G=334x9: 12965 / 4792
Quick conclusion from above:
*K10(BA) looks a bit faster than K10(B1), though multiplier aren't same.
*K10 score seems about 10% lower than Kentsfield at same clock.
So, K10 needs more clock!!!
I have own Kentsfield 3DMark06 results...
...haven't you seen my old post in this thread!?;)
I pick up them and list along with revised K10 results:
K10(B1) 2.4G=240x10: 10796 / 3560 -> 10926 / 3553 (with HT multiplier x4)
http://www.oohashi.jp/c-board/file/3....4G-240x10.png
http://www.oohashi.jp/c-board/file/3...2.4G_267x9.png
So, Kentsfield is ~10% faster than K10, for both Total and CPU score...
Edit: Ah, savantu is faster than me:)
Hmm strange,i went by HKEPC numbers here for yorkfield:
http://www.hkepc.com/?id=171&page=3#view
It seems your kentsfield is ~10% faster than Penryn quad used in HKEPC with 3% higher clock(2.4Ghz for your Kentsf. vs 2.33Ghz HKEPC Yorkf.)
On one side (kentsfield) this is ddr3, on the other (K10) it is ddr2 Is 3Dmark and cpu score dependent of memory?
What VGA HKEPC used?....:)
Ahhhhh.....kyosen-san, you're cheating........:D :p:
WHY did you run the Barchie with HIGHER fsb than it's default (200MHz)...?... :p:
Now to be equal, run Kendsfield ASLO at higher fsb (for example at 333MHz fsb)...... :D :p:
Memory bandwidth/latency has virtually no impact on the 3DMark06 CPU score:
A single 3GHz Clovertown scores higher than a QX6800 despite being paired with FB-DIMMs.
http://www.xbitlabs.com/images/cpu/i...8/3dmark-2.png
A few other reviews with dual-cores.
http://www.xbitlabs.com/images/memor...I/3dmark-2.png
http://www.xbitlabs.com/images/memor...z/3dmark-2.png
http://www.xbitlabs.com/images/cpu/a...d/3dmark-2.png
