GueD'S >> Could definately be a problem with your ISP. Try through a US proxy.
lowdog >> It is in the plans, but $400/year for a signature is a bit steep for me down here in Israel...
Thanks, got it ;)
Used a chinese proxy and works :)
At last i can use 095, thanks :up:
http://img.photobucket.com/albums/v6...coret0954b.jpg
the coolest, you should check , I´m from Brazil as well and it´s impossible to open your web page without using a proxy.
thanks
I know it doesn't work for some people, I am not quite sure why though. The server is in the US.
no problem , replied only to let you know.
thanks
ok im sorry im pretty sure this has been asked in here but i missed it. I've got .95 and .95.4 on my pc both have the tjunction ato 100*C is that were is should be at or how can i change it th e85*C? processor and board are in sig
~as a sidenote both read the cpu fsbxmultiplier wrong (states im doing 500x6 not 375x8) even with the system under load so i know its not throttle
Did you get the correct information about delta to tjunction from intel and is 100? not higher or lower ?
There was a thread that talked about that but some said nobody knew as intel has not released the info yet. Not trying to question your expertise at all just want to make sure so I do not burn my cpu trying to achieve higher overclocks.
Thanks for the great job
hlo
Thanks. This is great now I am showing realistic temps for my E6850 compared to 0.94 and 0.95.
Strange problem with me too. I can't download in two links on the first page of this thread. Can someone give me CoreTemp 0.95.4 via pm?
Thx, bros..
CoreTemp v0.95.4:
- File Version: 0.95.4.0
- EXE dated: 08/21/07 (182kB)
Q6700 G0 is identified as QX6700
thanks for the great utility!
My question still how do we know that the Tjunction is 100 and not another value ?
We don't, but I don't think it could be anything above 100C. That's the maximum Intel rates their mobile parts.
The link is broken for me :confused:
You may need to use a proxy server.
Why?!
Is there not just to email Intel and ask? maybe not couse you've allready done that i guess :) would they not tell? dont they self even know? and why not if so? and why dont they tell IF they knew? there have to be someone who know what tjunction there is! if they are so smart to integrate a DTS then they should want it to work correct to, why bother to put in there then?
Regards.
PS. Love the prog coolest :) used it since my day 1 of C2d :)
Actually there is, but I've tried that. Their response was that the desktop parts didn't have an actual way to read the Tjunction as they have an IHS, and thus use TCaseMax, which is the same for all steppings.
So Intel wasn't very helpful :(
I don't know, some people in some contries can't get to my server for whatever reason :shrug:
Cannot download 0.95.4.......
Bandwidth Limit Exceeded
The server is temporarily unable to service your request due to the site owner reaching his/her bandwidth limit. Please try again later.
Yeah, thanks. I just found out myself. I'll update when it's back up.
The Coolest: do you know why the difference in temps between Smart Guardian and core temp? (nearly 7c-10c during full load)
It's back up now. Sorry for the downtime.
