@FUGGER-Drwho?
Do you know what mean if the debug led say 00 error code when I'm starting the system? :shrug:
The board don't start again after a crash@5.6 GHz - 1.83V - @-165°C :(
@FUGGER-Drwho?
Can you get into the maintenance-BIOS by setting the jumper to 2-3 and bootup?
Nope! This is the problem :( I would try better this platform because the two cpus worked @ -165 and -170°C during the CPU Test :eek:
THERMTRIP kicked it, you should see a message on screen that the machine has been shut down due to x.
Usually pulling power for a full reset is best.
You also might be getting too cold.
Oh, you might have killed.
try single cpu's?
Yes, already tried. The first problems were there. I started without CPU0. After the boot I turned off and inserted the cpu again and after that the system worked good again. Now the system don't boot. But I insulated correctly and only after 45 min/1 h of tests it seems don't wokring fine again :down:
Dry it all out with hair dryer or overnight and hope it fires, might have condensation giving you a problem.
I tried now and...the Skulltrai lsystem wkoring again :up: Strange :D
You got lucky but then again, Intel boards and chips are very durable.
Im planning on another round of LN2 soon.
Hey, isn't Micron headquartered in Boise? They might hold up production of those sought after 333 FB-Dimms if you guys keep bashing their home state!! :P
As far as skull trail's viability goes, after showing these results to a couple of quantitative analyst/trader types who write their trading models in kxsystems' Q/KDB+ language, much drool had to be mopped up. In their world, the highest # of threads @ the highest clock in a single box under your desk can provide one's strategy quite the moneymaking advantage..or at least much safer trades after being able to execute (and possibly complete) more (or longer, or more longer even!!) simulations to aid in their decisions.
And here I am, as always, just having pulled the trigger on a new quad system for my new audio recording/mixing/mastering/midi rig thinking skull trail was still a ways off. I doubt I'll even stress 4 OC'd cores in normal operations w/ a bunch of plugins loaded although I'm sure I'll try to find a way or reason to justify why I should start designing a new one!!
Anyone know of a supplier in Canada (or will ship to canada) for either set of ram:
Mushkin 2X2GB PC2-6400 240PIN DDR2-800 FBDIMM 976596A
or
KINGSTON, 4GB (2 x 2GB) ValueRAM Dual-Rank KVR800D2D8F5/2G
I've been looking around some US sites have either or but they don't ship to Canada :(
update: nm .. found some :)
@FUGGER:
When you get a chance, can you put your BEAST through the x264 encoding benchmark run by XS member graysky?
This is one application where multiple cores should actually be utilized effectively and the top spot is held by dual clovers @ 3.0GHz (only :))
The XS thread is here http://www.xtremesystems.org/forums/...d.php?t=158199
The mainpage is here
http://www.techarp.com/showarticle.a...pgno=0#Results
Your "toy" @ 4.4Ghz should destroy this :)
I'd love to know why these boards are taking so long to become available...many places have them listed, but all have them backordered until typically late March-April. The CPUs are available, but not the boards.
Why the delay???:mad:
here is what i mean about slow booting skulltrail
video is the best way to explain it :D
http://www.youtube.com/swf/l.swf?vid...KyIOb3dZokW75e
you have obviously never owned a workstation board, bios always takes a long time to post.
has anyone purchased one yet BOXD5400XS???
or here D5400XS
True, i remember my 760MP board needed ~40sec from switching it on to VGA init. On this board it was the ECC ram that took so long, at least for me (so maybe the FBDIMMs are keeping it from booting faster?). Seeing this YouTube link dinos posted really makes me want to go dual socket again for folding.. gawd, SkullTrail rocks! :yepp:
