only time i might feel any warmth from the heatpipes was when i was P95 my quad @3.8Ghz....at idle, feels cool to the touch.
Ok then, it's probably just my cooling arrangement. I can live w/ quiet 3500. :D
whats the best bios version at the moment?
tnx :)
tnx for a quick response :D
has anyone tried M629B_12.B01 and memset 3.3?
i tried memset 3.2-3.3 and it's not working with M629B_12.B02 bios :(
Thanks guys. I went back and set up Vista on Intel's Matrix Array system. I created a volume for my programs and a second one for storage. Both are Raid 0. I bumped up the voltage to the SB like many said, and I got a stable array. :woot: I found out that many also had to enable VWBC in order to get high speeds, so I'm not worried about that anymore. :)
http://img229.imageshack.us/img229/4734/untitledvq5.jpg
Now that looks a heck of a lot better than the erratic graph you were getting before.
It looks damn near optimal!
i think i need this board instead of my crappy evga 680i i will soon be doing another rma because board shorted out again
i think a lot has to do with the modules you have installed...i am using 12.B02 and it is fine with me...i am running Teamgroup ddr1000 @980Mhz; SPD is prgrammed for 5-7-7-20-30 at 1000Mhz...i am at 4-4-4-12-20 and it is flawless up to now...no BSOD, no window freezes, no programs closing out on me...now...if i was a game-ster, it might not like those settings.;)
it all comes down to what your particular tasks you need to do with your computer and whether you have the right memory modules to accomplish it...i know there is another beta (15AT.B01) floating around (only for a few select have it, ATM) but it is not any better in memory speed..that new beta bios makes it compatible with more memory modules and allows better sychronization with 4 sticks of memory at default speed....i was told that it allowed for ddr1100 speed at default cpu clock speed...darn good if you don't intend to overclock!
This maybe the case .. what I found was that the 12.B02 would not allow for the GeIL modules to run the same timings, like it would not boot at 4-3-3-8 1T where as the 12.B01 does .. hence this is the one for my setup, in any case the Abit has allowed my various components to OC further and better than my other current P35/P965/680i boards and all this stock ... i.e. no vmods .... nice one Abit :D
Would be good to try the next Beta ;)
Guys I've great problem with this mobo and q6600... vdrop is great...mobo and the q6600. The vdrop is great. Can anyone post me the settings? Help me
The only "setting" that can help with the droop ->
http://www.xtremesystems.org/forums/...4&postcount=12
Maybe we should sig that kind of stuff...
you have a nice chip ace. i cant clock mine past 3.7 and be prime stable unless i set 1.53 bios. 3.8 needs 1.6 vios, droop is about 1.54=/ Iam able to boot n such at 4.1ghz for basic task
my memory checks out find at well over 900mhz though so thats good
hey guys...thought you might want to take a look at the difference between a kentsfield and yorkfield at the same operating specs doing video encoding bench...significant difference in results for only doing about 3Ghz.
http://www.xtremesystems.org/forums/...d.php?t=158199
Hey Ace, I just checked Abit's eRMA site and it has an RMA number along with my request number. I am not at hoem to check my email but I am guessing they agree with you and the board is bad. I will wait to see about an email before I Paypal them the cross-ship funds though.
just got my board back from RMA, the first thing i did was the Ace-A-Rue mod something i did not do with my last one and i'm running 500x8 with kool temps all around (i'm using H2O to cool the cpu) any way the vdroop on this board is worst than my last one Bios settings 1.62 actual 1.56 two questions
1st is should i do the vdroop and see if i can get higher oc or should i be content with what i got since it is running perefectly
my temps idle are cpu 28, mobo chip 29, pwm 29, my sys is next to a window which i cracked open a bit and since i live in WA state temsp are pretty cool right now. under load temps stay pretty cool also
2nd BIOS is B10 any need to upgrade?
i know what you guys can offer is more on the form of opinions since sys is running great just like to hear what others think, thx for the great help on this thread
