Hi guys, need a little help here. I'm using BIOS 1104. Got a Q6600, batch L807A413, 4x 1gb Corsair XMS3 1333C9DHX.
The following settings are stable:
CPU Level Up = Auto
Memory Level Up = Auto
AI Overclock Tuner = Manual
CPU Multiplier = 8
FSB - Memory Clock Mode = Uninked
FSB - Memory Ratio =
FSB (QDR) MHz = 1600
MEM (DDR) MHz = 1333
LDT Frequency = 5x
PCIE Bus Slot 1 & 2 MHz = 100
PCIE Bus Slot 3 MHz = 100
SPP<->MCP Ref Clock, MHz = 200
SLI-Ready Memory = Disabled
Memory Timing Setting
P1 = Disabled
P2 = Disabled
tCL ( CAS Latency ) = 9
tRCD = 9
tRP = 9
tRAS = 24
Command Per Clock (CMD) = 1t
tRRD = Auto
tRC = Auto
tWR = Auto
tWTR = auto
tFAW = auto
tRD = Auto
tRTP = auto
tRFC = Auto
tREF = Auto
Over Voltage
CPU Voltage = 1.35v
Loadline Calibration = Enabled
CPU PLL Voltage = Auto
CPU VTT voltage =Auto
Memory Voltage = 1.6
NB Core Voltage = 1.44
SB Core Voltage = Auto
CPU GTL REF0 Ratio = Auto
CPU GTL REF1 Ratio = Auto
CPU GTL REF2 Ratio = Auto
CPU GTL REF3 Ratio = Auto
NB GTL REF Ratio = Auto
DDR3 CHA1 Ref Volt = Auto
DDR3 CHB1 Ref Volt = Auto
DDR3 CHA2 Ref Volt = Auto
DDR3 CHB2 Ref Volt = Auto
CPU Configuration
CPU Internal Thermal Control = Enabled
Limit CPUID MaxVal = Disabled
Enhanced C1 (C1E) = Disabled
Execute Disable Bit = Enabled
Virtualization Technology = Disabled
Enhanced Intel SpeedStep(tm) Tech. = Disabled
CPU Core 2 = Enabled
CPU Core 3 = Enabled
CPU Core 4 = Enabled
Spread Spectrum Control
CPU Spread Spectrum = Disabled
PCIE Spread Spectrum = Disabled
MCP PCIE Spread Spectrum = Disabled
SATA Spread Spectrum = Disabled
LDT Spread Spectrum = Disabled
Right, my system is totally stable like that. No probs, but I can't get my Q6600 to 3,6 ghz as it needs 1.52 in Bios, with loadline enabled. Cpu-z reports vcore as 1.6. So, I am wondering if I could clock my RAM to 1600mhz. I know someone who had exactly the same ram as me, with this board, and got them 1600mhz with 9-9-9-24-2T @ 1.6v in BIOS.
I naturally did the same, passed 17 passes memtst, but froze after 5 minutes in Vista. Any suggestions?
