Q9550 + LANParty UT X48-T2R incorrect ratio????
Q9550 + LANParty UTX48-T2R stuck at 3.4ghz (8.5x400)
Corsair 4GB DDR2 XMS2 Dominator PC2-8500C5 TwinX
Now the mobo defaults CPU to 2.8 (stock speed yes i know) BUT sticks the RAM at 800Mhz....CPU-Z says this is a 1:1 Ratio
If i up the RAM to 400/1066 then all is good but CPU-Z says its running on 3:4 ratio now.
Why doesnt it run at 400/1066 by default.
I have the RAM in slots 1 & 3 on the mobo.
1 Attachment(s)
How many phases do these boards have in the memory power?
The LANParty UT X48, LT X48, and UT P45 seem to have 4 chokes around the memory. Two on either side. From the processor Buck converter we have become used to one choke per phase.
What does this configuration represent? Separate 2-phase supplies to each bank of 2? A single 4-phase supply? The inductors run in series for a different inductance.
Note that we are used the chokes being the same size. Here, one is 1µH and the other is 1.8µH. On the X48 boards, one of the chokes in each pair doesn't have a cover.
