Both very impressive. Nice chips!:up:
Thanks, I'm itching for the new ram. This "junk" i have now hits a wall at 4.4ghz. With this low voltage chip, can't wait to see some 3dmark numbers! :up:
http://i280.photobucket.com/albums/k...verclock39.jpg
I don't like how much voltage this takes. Any suggestions? It's only stable for about a minute on prime95. I'm getting to the point where I don't want to add any more vcore.
Q802A444
VID 1.1125
It's on a Rampage Formula
2x2G crucial ballistix ddr2 800
FSB Strap 400
FSB 435
DRAM 870Mhz
Command Rate Auto
CPUv 1.41875v
CPU PLL 1.62v
NB volt 1.45v
DRAM 2.20v
FSB term volt 1.30v
SB volt 1.075v
SB 1.5v 1.55v
loadline disabled
CPU GTL Auto
NB GTL Auto
DRAM controler ref. Auto
Thanks for any help :)
im in a simalar spot . can game etc @4.0 but im only just getting up to 3.75ghz with 1.328v and orthos stable at 4.0 it lock in about a minute even giving it 1.4v bios whihc i odnt fancy so i backed down.
also my vid is even lower 1.1v !
Lower VID is good?
I still really don't know what I'm doing. I'm coming from 939 Opteron170 on A8n Sli.
xeons counterparts batch Q807A091 are very good as the one I had ( yes vid is 1.07v but I'm not so sure it is very important past + 4ghz . I'd say low vid > high temps ) My current xeon 's ( Q746A534 ) vid is 1.115 and stable 4ghz with 1.29v not so much higher than Q807 , and supports 540 fsb max air so nice too .
4 ghz priming with 1.20v load
http://img155.imageshack.us/img155/5415/4hty5.th.jpg
or Tarowa and C1anid3' ones
I saw another good E8400 batch q745 stable with 1.21v like yours
what is your batch ?
my best ocing score so far with my e8500
http://i163.photobucket.com/albums/t...otos/8218s.jpg
yes , I'm actually thinking the lower vid you have , higher temp with such chips . Might be check for that .
My xeon Q746 has cooler temps for 1.125 vid with same TRUE 120
http://img444.imageshack.us/img444/4608/q746pr2.th.jpg
you should definitively consider as lucky :up:
I've been wanting to try 8.5x multi with this but I can't seem to input a decimal in the multiplier selection on my DFI P35. Anyone know if this is possible with my board?
its a Q741A403.. lol i havent even tested it on air.. only with a cascade
yep thats the real vcore... the guys in team japan run there chips with over 2.0v with ln2.. :D
oh and that was a 3h beching session
more screenies here
http://www.xtremesystems.org/forums/...d.php?t=184459
Do you think the increased demand for these chips has caused intel to produce chips inferior to the ones they were making?
Maybe they are taking all the nice ones and making E8500s?
yep I think that Intel today are selling the best 45nm chips as Xeon (Wolfdale o Yorkfield) and the inferiors for desktop
I will resale my bad E8400 and buy his clone the Xeon X3110
any feedback from E8500 batch q805a525 owners ?
I'm up to 3.6ghz on my E8400 retail from newegg with stock cooler. The specific stats on my chip are:
SLAPL MALAY Q81 0A237
This is with my voltage at 1.3v in the bios.
VID is 1.1125
