O.o...how did you get 3400 mhz...?!!?=!?! with dry ice?
PS: whats your complete stepping? CCBBE 0617 FMPW?
how goes it on air?
Thx
Bz
how goes it on air?
Thx
Bz
Not Dry ICE.... Just watercooled by EXOS .... :DQuote:
Originally Posted by Bazikstano
I was just for a try on air with stock cooler at 3GHZ @ 1.375 Vcore..;)
3400 was Just a Screen Of death....
http://www.thelab.gr/attachment.php?postid=433006
3320+ Mhz Just for a validation.....
http://valid.x86-secret.com/ccpuz.php?id=117304
http://valid.x86-secret.com/show_oc?id=117304
But Only 3200Mhz was stable.... ;)
http://img144.imageshack.us/img144/4970/clip2yd8.jpg
Very nice chip you got there.
Dagalidis,,,,,Very nice,,,,whats the TCaseMax and TDP reading on that one ???
and what are the last four letters DPMW or EPMW ??
cheers !!!
Jojojo, thats nice men...wich aircooler are you using for 3.0? what are your temps?
thx
BZ
DPMW, and yes those was the corect values (TCaseMAX & TDP) on CoreTemp....Quote:
Originally Posted by Alzedon
Bazikstano aircooler was the STOCK AMD Cooler....;)
O.o stock!!!!
how was the tº on full load and idle?
If i remember well 34C IDLE - 48C Full @ 1.352 VcoreQuote:
Hey guys .... Sorry for the MESS....:(
My stepping is CCBBE 0617 FPMW and NOT DPMW.....:D
Sorry again... Its time to correct my signature also...;)
WOIW Dagalidis, thats AWOSEM....so little vcore, so god temps with STOCK!!!! I cant believe...so there are selling thes stepping on ebay...Im going to get IT!!!
But..I was wondering if you could give me the complete code..everithing that was on the top of the processor..=D
LoL....Quote:
You forgot the 1st RULE ....
LUCK....
If i remember well the batch number was close to 60.... (XXXXXX0058) or something...:D
Just make sure you find CCBBE 0617 FPMW and the rest .... just hope:D
I'm bidding on a CCBBE 0617 FPMW right now, hopefully I can get it :D
@Dagalidis: Thx im getting one =D
and...was you SP2004/prime stable?
Bz.
Guys I see a CCBWE 0608 MPMW. How do you think this does?
On the front page only CCB1E 0608 MPMW is mentioned.
I would personally stay away from any ccbwe. Theres plenty of ccbbe in forsale forums and ebay.Quote:
Originally Posted by GMX
Which forsale forums? Get their ads in XS!!! I only got 100+ posts here(because XS RULES!!)
Plus there are not many on ebay for me(in AU)
Great thread guys. Well done on the compilation of statistics. I just ordered a 165 from Monarch and am hoping for the best. If the stepping sucks back it goes and I'll post here for anyone contemplating a buy from Monarch. I have a great chip now but the 165 looks to be great fun.
Wonder if I can take this any further. Got me a CCBBE 0615EPMW, got it from thenerds.net and its looking nice, got it to run prime stable at 300x9 for 1 hour and 30 minutes on what should be 1.35V, but actually 1.375V. Temps are a bit high so I guess I'll need water cooling or better case airflow to take it any further.
Idle is ~35/31, load is about ~49/50.
What do you guys think? I stuck a new silverstone high pressure fan on my TT Big Typhoon, running it at max speed as well as my other silverstone on exhaust.
Tahts really too hot for a BT on stock Vcore, even on stock fan! Your ambient temp?
Are you sure its mounted properly and with enough pressure, not too much thermal paste?
Also chekc CoreTemp to see if both cores temparatures are in line, maybe your IHS is making bad contact on one of the cores. Also you can see if it gives you lower readings than your mobo sensors, they could be off wrong.
edit: I see you already ran CoreTemp... minimal differences so I guess its remount time.
Hi, got some strange core readings anybody know why core #1 is below the cpu temp ? when idle
http://img89.imageshack.us/img89/549...curate1pc7.jpg
Core #1 tempreture rises and falls twice as fast as that of core #0
http://img246.imageshack.us/img246/1...titled1na7.jpg
Also core #1 can be as much as 17c above core #0 when under full load :eek:
http://img140.imageshack.us/img140/4...titled2gp1.jpg
Its prime stable 12hrs at 2.65GHz 1.4v core #1 is the problem and is always first to fail when volts are increased above 1.4v, any help appreciated.
pop the IHS, that's really the only thing I can think of.
BTW people, AMD prices dropped, see News section. 165s are ~$160 and 170s are only $200! :eek: :D
Well I remounted for fun anyway, got Zalman grease coming in today, so probably gonna remount today anyway. Well when I did last night I noticed poor coverage of AS5, it was patchy in the middle with little paste and most coverage away from middle. :(
Guess I need to check if both surfaces are flat in contact, or is removing the IHS my best option?
I live in Florida, its still hot around here at this time, I guess ambient is probably 23C outside case and most likely 25-26C inside the case.
hi evrybody i'm new. i visit the forum for a long time, but it's time to me to do my best in english :D
i have some problem to overclock my opty 165.
CCBBE 0615 EPMW ( i decaps it this morning )
I have some BSOD some times, but i have done somme occt, and i was stable. Same for the memory, some memtest @ 250mhz ( stock speed & stock timming of my PC4000HZ 2*1GB ) but some times ... i have some reboot, or when i boot some times shutdowns :(
One time the problem come frome ati2vxx.exe one time other programme from kernel, but any link between them :confused:
I really think my mobo don't suport my Club 3d x1900xt 512 ( no oc )
My mobo is an AN8-SLI, And i have already buy an seasonic 650 E+, i was thinking the problem was from PSU. ( before an antec True power 480TP. )
I use last bios and drivers on XP64. CnQ disabled. I have for hard drive Two Diamond Max 10 sata 16Mo 300go used in raid 0 ( 10go system / the other for programes ).
i know computers well, but there i'm very confused, i don't know where it come. :confused: This problem don't let me overclocking my cpu ( as i see very well steping great i want 3ghz :slobber: )
Thx evrybody :woot:
madcho-
If you have a straight A8N SLI or Deluxe (not the premium or A8N32) then there is a problem running any RAM at 1T above 240-250FSB. You need to set 2T on the RAM as you move through 240-250FSB. Sorry mate, it is one of the downsides of overclocking on that board. Try 2T and see if it stabilizes.
I have an ABIT AN8-SLIQuote:
Originally Posted by Merc14
http://www.pcinpact.com/images/bd/news/19547.jpg
edit : my problem is there with and without oc
